IMPORTANT suspension info
Guest cul08r
  • Guests
Hi Guys,
Well it has been a while since I have posted here and just though I should update you all on the SAGA with my suspension knock.
As most of you know, I was referred back to my suspension place by 3 different Ford dealers who blamed the knock in my front end on all sorts of things, centering around my lowered Kings springs and Whiteline swaybar. These included my struts, the strut tops, the swaybar bushes and the upper and lower control arm bushes.
Last week I had the control arm bushes replaced by a Ford dealer at my expense ($750) which failed to resolve the problem. I finally had it into the suspension place today and the problem was found, and fixed. FREE. No parts replaced. A 10 minute job.
With one mechanics head under the car, on an uneven piece of driveway, they saw that the swaybar support was loose as a goose, and were then able to replicate it on the hoist. The bracket is not the one that holds the bush around the swaybar, it is the one that joins that bush and bracket to the chassis rail. It is about 9" long, and black metal.
The four bolts that hold this black bracket to the chassis (2 inside and 2 outside chassis rail) were extremely loose, allowing the whole bracket to move about 1 inch forward and backward when the suspension flexed...
Time off work and travel expenses going to 3 different Ford dealers to check the problem: $500.00
Replacing upper and lower control arm bushes: $750.00
Phonecalls to dealers and suspension place: $30.00
Seeing the look on my face when the guy showed me the FREE fix, that should have been spotted by the first dealer....PRICELE$$
Andrew
https://www.fordxr6turbo.com/forum/topic/12267-important-suspension-info/
  • 00-XRG / 006-FPV
  • Member For: 22y 6m 22d
I resent that!!!
But good to hear it was a nice easy fix. Bad to hear that it cost you over $1k
Adam
Guest cul08r
  • Guests
Grant,
I don't quite understand your question. Am I missing some subtle undertone, or am I misinterpreting your question.
I have the original bushes in my garage, and the new ones are still in the car. I am not chasing anyone for money or anything, but I am expecting top notch service from the suspension place when they lift my 4WD this friday!
Goose, I didn't want to ruin your reputation...
Andrew
  • EMS makes MAGIC MUMBO !
  • Member For: 21y 6m 16d
Andrew,
Good to hear that you've finally got it resolved ! Unfortunate it has cost you so much in $$$ and time though ! :blink:
Having now sorted out the issue, and having the bushes replaced for no apparent reason, can you say that the lowering of your car (Which is with the same springs I have in mine, except no swaybars) did in fact damage the bushes, or was that just the dealers way of fobbing you off ?
Just interested to know if I should have them loosened, and re-tightened at it's current ride height like mentioned in your earlier post about the clunk !
Thanks in advance
  • Member For: 22y 6m 26d
  cul08r said:
Grant,
Andrew
Ah, ok. I thought that Ford made you pay for replacements when there was nothing wrong with the originals, my bad.
Grant
Guest cul08r
  • Guests
Pretzel,
I would recommend getting the place that fitted your suspension to put the car up on a hoist that supports the wheels (as opposed to letting them hang free) and getting the bushes loosened off and re tourqued to the correct settings at the new alignment. A professional place like pedders apparently does this as standard practice but I am not aware of the exact torque figure that is required. I will never know if I needed the bushes replaced, because they were quite damaged in the removal process and could not be properly evaluated.
Also get them to check if the bolts I mentioned are loose from the factory and require tightening.
Grant,
As I said above, I will never know if the original control arm bushes were at fault. What I do know is that after fitting them there was no change in the vehicle that I noticed, and the problem was not solved. The Ford dealer have stated that there was excess movement in them and they are too damaged to test, due to the hammers and screwdrivers that they obviously used to remove them.
I am just stoked that at 6pm I will have my old T back (I have barely driven it in 6 weeks) and now I can hopefully sell it with confidence...
Andrew
Edited by cul08r
  • Member For: 21y 11m 4d
Andrew
Glad to see the problem,s sorted,truly sorry to see your selling the T :idunno: .What are you going to replace it with?
  • Weird Member
  • Member For: 22y 4m 25d
  Quote
I see the problem...you are indecisive....
One car is too low, the other too tall. :lol:
Best not to think of all the other things you could have spent that $1K on... :idunno:
