  • Replies 20
  • nutter
  • Member For: 21y 3m 17d
its hard for me to justify the answer to this as that we have an xr8 sedan and a xr6na ute, but ill say that the ute is much better on the handleing side... the 8 does feel more front heavy
  • Member For: 22y 19d
This will be an interesting thread... :gooff:
Carty,how can you compare an xr8 sedan and a xr6na ute???Different weights over the front and different power delivery...
  • Member For: 21y 23d
I own a NA XR6 ute and had a courtesy NA XR6 sedan for nearly two weeks and can honestly say I prefer the ute there have been many occasions when I have been giving the ute an absolute canning and often wondered wether It was all going to end in tears but I still havent reached the limits of my car :gooff:
but did more more than once in the sedan travelling at lower speeds. :nono:
To me the ute rear end seems to be far more balanced although skitish on off camber bumps apart from that very glued!
The way the sedan sharply broke away from me on hard cornering felt like I was driving one of my mates Commodores (insert shorter wheelbase) :gooff:
  • nutter
that's why I said "it is hard for me to justify this"
but I have driven na xr6 sedans before also, just not as to the limit that I have taken my brothers (I delivered cars home to people after thier service while I was working at the local dealer)
  • Sucker
  • Moderating Team
  • Member For: 20y 11m 28d
The utes skip around quite a bit more than the sedans - but it makes it all the more fun!!!
At low speeds I don't think you would notice much of a difference, but when the go pedal is getting a workout you have to be on the ball. It doesn't take much for one of these little babies to hang their tail out around corners.
Trent.
  • Member For: 22y 2m 24d
With phase II power, my ute constantly surprises me at the amount of traction is has. Yes it gets skitish and jumps around a bit but if you keep on pushing it, it will go through that stage into controlled power oversteer that can be controlled quite well.
The electronic throttle is a bit of a pain as you don't get the response you get from a cable to steer the car through the power slide. Fun though.
  • Artificially Aspirated
  • Member For: 21y 3m 11d
  xr6ikness said:
Leaf spring rear compared to IRS say no more
C YA :w00t2: JEFF
I watched that brittish show top gear today and they reviewed the new C6 Corvette... It's got leaf springs!
  • Team Bute
  • Member For: 21y 9m 7d
C YA :w00t2: JEFF
It's NOT as cut and dry as that.
The Leaf spring setup has been refined over many years, and is as good as it gets.
The IRS Control Blade system on the sedans has the potential to be the best, but as it is still new, has some fine tuning to be done to maximise its inherant engineering advantage. Maybe BA II will be better.
As far as I'm concerned, my ute is absolutely fantastic in the handling stakes..... on dry roads that is. Had a little scare about a week ago in the wet..... but then again, I'd expect the same from the sedan's IRS rear if the TRACTION Control was off.
I was considering the SS ute, because of the IRS rear on the Holden.
But after a short drive, the Expensive Daewoo was NOT a patch on the XR6 as far as handling and comfort (read that as compliant suspension) go. The XR6 Ute has an excellent standard suspension setup.
cheers
tom
