  • Member For: 22y 7m 26d
eat V8> I'm sure some of the guys really appreciate your offer and may take you up on it. Even though the BA is not a model your parts people would know about, the fact is that the engine has the same crankshaft and conrod dimensions of the old 250 motor and there are plenty of speed shops in the US who service go fast bits for them so there should not be a problem at all with conrods for the BA motors.
  • Member For: 22y 6m 7d
Don't forget that you will need a full gasket kit including head bolts etc.. If your going to do the rods you may as well do the pistons too.
  • Site protagonist
  • Member For: 22y 24d
What sort of pistons are available for the "T" and which would be the best for the job.
Geea. :gooff:
  • Member For: 22y 6m 4d
I asked that a while back... Rob Herrod recommended forged pistons but a few people on here suggested that was excessive. Mind you, that was when APS were after cars for testing their product and no-one really had thought of power levels getting to where they are now. I think that Nizpro or Brian would be the people to ask since they are the ones replacing the pistons in their kits. Unless I'm much mistaken, APS don't change them in their kits to date.
Grant
Forged pistons are over the top IMO - I have cast eutectic (spelling?), the same as Ford use in the BA and I've put over 20psi without damage. Admittedly it was short term only during early testing, but the motor did cop a thrashing during that time. Blew two sets of rear tyres and a clutch in a three month period :blink:
I now run no more than 10 psi and the motor has lasted as good as any NA motor. It's now about six years since I built it up so that speaks heaps for the cast eutectic pistons. BTW it also runs standard conrods.
  • Toughest BA Turbo
  • Member For: 22y 5m 12d
Hypereutectic pistons are cast pistons, and about 30% stronger than normal cast pistons.
Although these can take reasonably high boost (say to 25lb) they are known to be brittle if run with the wrong A/F ratio. I've just bought an 2.5 litre STi motor, but replaced the hypereutectic pistons with CP forged pistons. The guy I bought the motor from had just destroyed one of these pistons in another motor.
If you want to run mid-range boost, IMHO 1.3 bar or less then you can probably get by OK with stock pistons. I like to run 1.5 to 1.7 bar boost on my turbos and usually install forgies as a matter of course.
Running 10lb or less boost I wouldn't bother changing the pistons.
Brian
