Oil Air Seperator Modification
  • Site protagonist
  • Member For: 22y 1m
  Big Mick said:
Alright, I have connected a fuel filter inline with the breather tube from the rocker cover to the inlet in the crossover as per EXR24T's mod and it is now running as an experiment.
I did a number of pressure readings (with the engine at wide open throttle while driving) prior to fitting the filter and then once the filter was installed and there was no noticable difference with the filter in place.
I will retest again in a week or so as the filter will surely provide a greater restriction as it does it's job with the oil vapour.
Out of interest I reckon the filter was slightly darker in colour just from the testing I did with it.
EXR24T, I also thought about the industrial oil/air separators but dismissed them as I thought they would be too expensive and may not work well at our low vacuum levels. A lot of them are designed for compressed air at 600+kPa.
It will be interesting to see what you come up with.
Mick
I'm looking forward to hearing your results Mick. :blush:
Geea. :w00t2:
  • Replies 26
  Benny said:
Hey guys I know this isn't made for the T but this is a Cusco 3ltr oil catch can out of my brother inlaws GTR. Just thought you might be interested in seeing its construction. Anyone got any ideas as to why they come so big when blow by produces only small amounts of oil.
The bigger the area inside with the ss wool the more chance of oil mist gettin trapped I would think?
  • In Your Face
  • Member For: 22y 3m 3d
  EXR24T said:
pic 2.
Ok l did some reading on these Microfliters and what they say is
  Quote
MICROFILTER
for 99.999% clean compresed air type LFM_1/8_S
You can also get them in 1/4 & 1/8 sizes too.
The supplier is FESTO
Now what they do is remove almost all of even the smallest water and oil droplets as well as dirt particles from compressed air. It also has an automatic drain vavle that you can attach to it and run it down the engine bay.
What my question is will these MICROFILTERS do the job for what we are after?
Guest Big Mick
  • Guests
Quick update on the fuel filter mod.
After almost a week of driving (including about 7 runs at Heathcote) there is now a drop of oil in the bottom of the filter. OK it doesn't sound much but hey, my engine isn't using any oil anyway.
My dipstick hasn't popped out so there can't be a lot of pressure in the crankcase.
This is looking promising at this stage!
Oh and I cleaned the existing oil from the crossover and piping to the inlet of the turbo prior to Heathcote. So it will be interesting to see if this returns after a few weeks.
Mick
  • Member For: 21y 16d
Good news Big fella, :smilielol:
I could see no reason why it would'nt work when I discussed it with you in earlier posts. Whre did you mount it and how did you connect it all up
macka
Guest Big Mick
  • Guests
Yeah, yeah you told me so...
It's a bit rough macka, but I'm not entering in any shows. I'll post a pic and a list of the parts I used later in the week.
Total cost was around $18, but you will have to replace the filter at a regular intervals (to be determined).
Mick
:spoton: Big Mick does'nt matter what it looks like as long as it does the job. I would'nt be holding my breath till you haveto change filters. :thumbsup:
Now that you know it works you can make a pretty one. Can I suggest that you go to a 4x4 wreckers and check out a Nissan or Mitsubish Diesel engine. Buy the bracket that bolts on to the head and also the filter head. As these filters are a reasonable size probably holds a litre, should'nt have to change very often. Maybe every 12 months I reckon maybe even longer
Go down to any auto parts shop buy a new filter. As these have a metal case you can sand and repaint. Connect up to your breather hoses and you should have a neat looking Air/Oil seperator
Let me know what you think
macka :holiday:
PS Mitsubishi filters are probably cheaper
