Oil/Air Separators
Guest Big Mick
Guest Big Mick
  • Guests
I will have a look tomorrow underneath a XR to see how hard it would really be to tap some sort of fitting in somewhere. It would be nice to have it draining automatically, rather than having to manually empty it every X amount of kays....
Mick, I agree it would be better to plumb a drain it back into the sump, but unless there is an existing hole I ain't going to drill and tap a hole in the sump while it's still on the engine :glad: .
I'll be interested to read about what you find tomorrow.
Mick
  • Replies 48
Posted Images
  • Site protagonist
  • Member For: 21y 9m 12d
I tell ya, you guys are bastards. I was going to have a bit of a relax tomorrow and now it looks like I'm going to be busy. :pinch:
Geea. :glad:
  • Member For: 21y 6m 18d
its good to see you have been doing you homework mick very interesting reading and would explain why so many of us are having problems with pinging.
  • Dark Knight Mafia Member No. - 666
  • Member For: 21y 11m 29d
Usign an oil catch can would be very useful for all you guys running higher boost, I'm going to get one even though my car is currently stock, it would be helpful on stock cars to as the emissions from the top of the rocker cover go back through your intake and lower your octane levels.
I bid on one on ebay the other day, I didnt win though. It is one that doesnt drain back into the sump but has an oil level meter on the side and a filter ontop. I have been told thought that vented catch cans are not legal, but I am not sure on that.
Here is the link to the catch can I bid on, as you will see you can pick them up pretty cheap if you cant build your own. Here
That looks too big for the T,where would you mount the mother??
I had my turbo pipes off when I put in extra heat shielding in(to try and stop the paint from bubbeling,now I just think its just a :gooff: paint job) and wondered where that oil film came from,stupid ford :kissmy:
  • EMS makes MAGIC MUMBO !
  • Member For: 21y 2m 12d
I would personally prefer the oil that is caught from the fumes to not be returned to the sump, and to monitor the amount collected (An indication of engine condition)
If you think about it, the oil being collected in the catch can is from blowby picking up oil (Burning oil perhaps ?) so the oil returned to the sump would be contaminated ! :blush: I'd be much happier to replace the oil with fresh oil when enough comes out to be needed !
The other issue you would find with those cheap oil catch cans, is the size of the lines (I have seen one and they are too small) The lines would need to be at least as big as the one fitted by the factory that is plumbed back into the manifold.
Just my thoughts !!
I had my turbo pipes off when I put in extra heat shielding in(to try and stop the paint from bubbeling,now I just think its just a :spit: paint job) and wondered where that oil film came from,stupid ford :blush:
The can is only 6", it looks huge in the photo but every can I have seen fitted to a car is about that size.
fitting any size can will be an issue in a T, but where there is a will theres a way.
  • Member For: 20y 10m 25d
The oil vapour is created by the spalshing of oil etc in the sump the hotter the engine and the harder (more revs) your giving it to your engine the more vapour you will produce
The reason this vapour becomes a problem is that the crankcase does become pressurised because of blow by, (air fuel mixture forcing its way past piston rings) blow by is more pronounced in turbo cars due to the higher cylinder pressures
(boost plus normal atmosphere = higher pressure)
In a factory car (EPA compliant) the vapour is routed back into the inlet tract to be burned in the combustion process.
problem is that small amounts of oil vapour dramatically alter air fuel (effectively lowering it) ratios as you guys with modded cars should realise even a few tenths of a point will make big differences!!
there are no adverse affects from draining the recondensed oil back into the crankcase (it hasnt been cooked etc)
Just understand its not epa compliant that doesn't mean I won't install one though!
Oh yeah and they are required at many CAMS sanctioned motoring events!
  • Moderating Team
  • Member For: 22y 24d
Just had a look under a XR, the only spot on the sump to attach a fitting would be maybe underneath the oil filter (the "ridges arent all that raised there), removing a sump is a huge job! or... a tech suggested this one to me.... tap into the oil drain for the turbo? Id have a look at a T but the only one is 10 cars deep and I cant get it on a hoist today..... :blush:
  • Site protagonist
Went for a drive to autobarn. They have a oil seperator can there with a screw in th bottom for $70. its a good size (looks about 6"-8"). What sort of pipe and connections would people recommend. Also after having a look under the bonnet, I was wondering where the best place to mount it would be.
They also have the can with the pipe on the end if you want to drain the oil to another part of the car.
Look forward to any input.
Geea. :glad:
