turb06 Dark Knight Mafia Member No. - 666 Member 3,667 Member For: 22y 3m 25d Location: Toowoomba Posted 26/07/04 12:59 PM Share Posted 26/07/04 12:59 PM I am wondering what brand and model # fuel injectors are used in the APS kit, or infor on any other fuel injectors available for the T. Also are fuel injectors designed to be model specific or are they pretty much a universal fit on most cars.Thanks. Darren. Link to comment https://www.fordxr6turbo.com/forum/topic/11995-upgrade-fuel-injectors/ Share on other sites More sharing options...
xlr8ed Phantom lives Member 1,417 Member For: 21y 1m 29d Gender: Male Location: who knows Posted 26/07/04 01:02 PM Share Posted 26/07/04 01:02 PM not sure of brand but I got six for sale that I had in my aps phase II Link to comment https://www.fordxr6turbo.com/forum/topic/11995-upgrade-fuel-injectors/#findComment-147250 Share on other sites More sharing options...
Guest LOK@ChipTorque Guests Posted 26/07/04 08:59 PM Share Posted 26/07/04 08:59 PM Hi Darren,The "T" injector is very specific if you want to replace it with the same type. The originals fire the fuel into each port (two cone shaped sprays) at specific angles. There are a multitude of injectors that will run quite happily in the T as an upgrade and the emissions and drivability vary with the type and size of injector selected but I personally would be using the correct Bosch twin spray units as an upgrade. There's a heap of info in the forum. Search for injectors or have a look at Geea's mods. If you still have questions, PM or ring Stef@ChipTorque. We have stock on the shelf.Lachlan Link to comment https://www.fordxr6turbo.com/forum/topic/11995-upgrade-fuel-injectors/#findComment-147297 Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 22y 3m 2d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 26/07/04 09:56 PM Share Posted 26/07/04 09:56 PM Bloody injectors, sh*ts of things, good luck in your quest Scotty Link to comment https://www.fordxr6turbo.com/forum/topic/11995-upgrade-fuel-injectors/#findComment-147306 Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 10m 14d Gender: Male Location: Newcastle Posted 26/07/04 11:13 PM Share Posted 26/07/04 11:13 PM I'm pretty sure you can use Bosch injectors part no. 0 280 155 968. Around 400cc flow rate I think and correct spray pattern for the twin cam port setup. Link to comment https://www.fordxr6turbo.com/forum/topic/11995-upgrade-fuel-injectors/#findComment-147341 Share on other sites More sharing options...
Blown BA In Your Face Member 6,195 Member For: 22y 3m 10d Gender: Male Location: Peninsula Posted 27/07/04 06:35 AM Share Posted 27/07/04 06:35 AM Benny said: I'm pretty sure you can use Bosch injectors part no. 0 280 155 968. Around 400cc flow rate I think and correct spray pattern for the twin cam port setup. Yep that's the ones l've got about time Link to comment https://www.fordxr6turbo.com/forum/topic/11995-upgrade-fuel-injectors/#findComment-147467 Share on other sites More sharing options...
turb06 Dark Knight Mafia Member No. - 666 Member 3,667 Member For: 22y 3m 25d Location: Toowoomba Posted 27/07/04 01:28 PM Author Share Posted 27/07/04 01:28 PM are they sh*ts of things to install? Link to comment https://www.fordxr6turbo.com/forum/topic/11995-upgrade-fuel-injectors/#findComment-147638 Share on other sites More sharing options...
GOLDIE My new toy Lifetime Members 5,344 Member For: 22y 1m 28d Gender: Male Location: stanthorpe wine capital of qld. Posted 27/07/04 07:39 PM Share Posted 27/07/04 07:39 PM turb06 said: are they sh*ts of things to install? Not to hard to install about 3/4 hour but I would not recommend you run them on the standard computor as it would appear it can not trim the fuel flow enough.Is that right scotty. Ian Link to comment https://www.fordxr6turbo.com/forum/topic/11995-upgrade-fuel-injectors/#findComment-147665 Share on other sites More sharing options...
Guest Guests Posted 27/07/04 10:00 PM Share Posted 27/07/04 10:00 PM So I take it long tall sally not happy jan,ian? Link to comment https://www.fordxr6turbo.com/forum/topic/11995-upgrade-fuel-injectors/#findComment-147672 Share on other sites More sharing options...
turb06 Dark Knight Mafia Member No. - 666 Member 3,667 Member For: 22y 3m 25d Location: Toowoomba Posted 28/07/04 12:45 AM Author Share Posted 28/07/04 12:45 AM hoot said: So I take it long tall sally not happy jan,ian? Link to comment https://www.fordxr6turbo.com/forum/topic/11995-upgrade-fuel-injectors/#findComment-147709 Share on other sites More sharing options...
