Quarter mile times wanted
TurboDewd
  • Site protagonist
  • Member For: 21y 10m
10.351 seconds
138.6 mph
6 speed
15 psi
slicks
455 kw at wheels
<{POST_SNAPBACK}>
OK I'll bite. *cough* bullsh*t *cough*
When, where, and who were the witnesses.
<{POST_SNAPBACK}>
Come now, I dont bullsh*t.
<{POST_SNAPBACK}>
Tell us about your engine mods... :gooff::nono:
<{POST_SNAPBACK}>
5.7 LS1
8.4-1 comp
ross forged pistons
Eagle H-beam rods
fairly mild cam 228-236 @ .050
bit of head work
Whipple 3.3 litre positive displacement s/c 15psi
all the other usual sh*te.
<{POST_SNAPBACK}>
I used to run against that in my old car. All I used to see was the sparks flying off the rear end at every shift as it disappeared into the distance.
One very quick car.
Geea. :nono:
  • Replies 212
  • Site protagonist
Geea, I hope I did not offend you with my comments yesterday, I did not mean to,  It is just since I joined  here, I have not herd such negitive comments from you before. I might have read it wrong. I was just saying to lochlen, when he tuned my car to 273.6rkw that I had never herd you give neg comments. he allso tuned it when it was 240 rkw. it has got bigger injectors, I got them from lochlen,  about the stall, it would be best to have a talk to lochlen for proof of that I think he thouht it was pretty big,no limp. no edit. as for 12.6 @ 107 mph , it is possible to pull 12.6 at 104 mph, in a well set up car, I will fax my time sheet to you if you give me a fax number, I am not able to scan, I have folowed your info from when I first joined, and owe most of my improvements to you, thanks for that. I would like to meet you and have a chat sometime, maybe at willowbank some time. As for the temp, the dyno compensates for this and balances the power figures, so the only loss on the dyno up here, is the extra restriction in the inlet.  this is in shootout and the idea of it is so that everywhere can compare figures. hope this settles your doubts. thankyou for listening, we can all learn from each other. ps Craig I was not being smart at your accomplishments, I wanted to know your thoughts on what I said about to much power on street tires, that's all. I felt you must have had a very smooth power dilivery to run that time 11.9. sorry if I offended.
<{POST_SNAPBACK}>
Blueboost, I didn't read you post yesterday so I wasn't offended. I have reread your initial post here and I owe you an appology. I thought you said it had standard injectors. This is what I based most of my reply on. If you have the larger injectors then the power figures you quoted are very possible. This would also make the times you quoted possible too. 12.6@107 is unusual though. This could probably be explained by the Nitto's and higher stall giving you a good 60'.
How hot and humid was it when you were running?
Sorry again for doubting you and congrats on a great time. :gooff:
*shuffles off to take foot from mouth* :nono:
Geea. :nono:
  • Member For: 20y 9m 13d
Hi Craig, it was in Nov when I ran that time, it was about 30 degrees, and 80 % humidity, so it had nothing going for it. ithink what has happened is not many have ran that lower power on nitto's, with that bigger stall, so it gets the comple use of all that touque the xr6 makes. my brother has a GT BA, with cold air and edit, it shwed 240rkw, but felt very slow next to mine, all that touque again. The heat up here is the reason I have waited so long to run again. any way I am going to have a go at the 11, I know it is a fair bit faster now, but if it does not make it . (more modes on the way. Cheers
  • 3 weeks later...
  • Member For: 21y 6m 16d
2nd run without the extra weight
14.41@102.6 2050rpm launch SSS auto mode with wheel spin
3rd run
14.26@103.8 1900rpm launch SSS auto mode 5.8sec 0-100 (didnt catch the 60ft time.
But overall fairly happy with 14.26 with no injectors edit or chip yet, oh btw had the shift kit off aswell will post any imporvment with kit on next week.
  • 3 weeks later...
