Blacknight Member 16 Member For: 21y 14d Location: Sydney Posted 15/07/04 11:26 PM Share Posted 15/07/04 11:26 PM Hi Guys,My car is having trouble just wanted to see what your thoughts are. Whats the Problem? This has happened twice now and I've booked it into the dealer for next tuesday. Whilst cruising along at about 70kph I put my foot down and at about 3000rpm I lose acceleration there is a big rumble. If I slow down the car seems like its gonna stall if I try to keep pushing through it struggles for a bit and then regains power. Whats Going On Any Thoughts Suggestions would be appreciated. I've Done 6000km in the beast.CheersBlacknight Link to comment https://www.fordxr6turbo.com/forum/topic/11841-whats-going-on/ Share on other sites More sharing options...
Tex Member 56 Member For: 20y 11m 18d Location: Brisbane Posted 15/07/04 11:48 PM Share Posted 15/07/04 11:48 PM (edited) Blacknight,Clould be over boost cut out. If the computer see's a higher than expected boost it will cut three injectors. I believe the way to get power back is by giving full acceleration back off then full acceleration again. Lachlan from Chiptorche (LOK@ChipTorque) told me how he can tell you exactly what to do.Tex Edited 16/07/04 12:04 AM by Tex Link to comment https://www.fordxr6turbo.com/forum/topic/11841-whats-going-on/#findComment-143797 Share on other sites More sharing options...
Blacknight Member 16 Member For: 21y 14d Location: Sydney Posted 16/07/04 01:41 AM Author Share Posted 16/07/04 01:41 AM Thanks Tex that could explain it anyone else can think of anything or has experienced the same thing?Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/11841-whats-going-on/#findComment-143813 Share on other sites More sharing options...
Dr Z Member 378 Member For: 21y 2m 19d Posted 16/07/04 06:55 AM Share Posted 16/07/04 06:55 AM As I mentioned in another post, with similar intermittent concerns, I sent an email to my Service Adviser which contained the following:"Check and clear fault codes in addition to ensuring that the engine management system is OK, which includes:· Check that “C” connectors on original PCM are plugged in correctly.· Check that wastegate control solenoid is connected securely.· Check for sticky swing valve in turbo housing.· Check that the bleed solenoid is not partially blocked.· Check “OC” valve sensors that go into cam caps.· Check vacuum lines.· Check ALL hosing and connections.· Check and/or clean and/or replace throttle body.Please ensure that all these checks are made. On pickup of the vehicle, please provide in WRITING an assurance that all the above checks have been made, including mention of any replacements."I know this is a shotgun approach though.. *touch wood* ..since then I have not experienced any more intermittent gremlins. Hope this helps in some way. Safe and happy driving...Dr Z. Link to comment https://www.fordxr6turbo.com/forum/topic/11841-whats-going-on/#findComment-143903 Share on other sites More sharing options...
CJF077 The Noble Leader Administrator 4,786 Member For: 22y 6m 29d Gender: Male Location: Sydney Australia Posted 16/07/04 09:59 AM Share Posted 16/07/04 09:59 AM i got exactly the same problem with mine, did the above fix it? Link to comment https://www.fordxr6turbo.com/forum/topic/11841-whats-going-on/#findComment-143958 Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 3m 10d Gender: Male Location: Sydney Posted 16/07/04 10:15 AM Share Posted 16/07/04 10:15 AM Sounds like the car is over boosting and going into limp home mode. Mine's done it too. I turned ignition off, turned it back on, and all is rosy. Link to comment https://www.fordxr6turbo.com/forum/topic/11841-whats-going-on/#findComment-143969 Share on other sites More sharing options...
Dr Z Member 378 Member For: 21y 2m 19d Posted 18/07/04 07:57 AM Share Posted 18/07/04 07:57 AM CJF077 said: I got exactly the same problem with mine, did the above fix it? Chris, even after a few thousand kilometres, still no intermittent gremlins here.. *touch wood*Cheers, Dr Z. Link to comment https://www.fordxr6turbo.com/forum/topic/11841-whats-going-on/#findComment-144463 Share on other sites More sharing options...
