  • Member For: 21y 23d
let me tell you changing springs at home etc by hand is fugging scary its like holding a bomb ready to tear you a new one! :spoton: ( the force needed to compress springs is well lots)
But truthfully if you can spin a spanner and have the spring compressors (they are relativley cheap to buy) you chouldn't have any problems and assuming the Kamc kit doesn't need to be adjusted go for it just be careful :crybaby:
https://www.fordxr6turbo.com/forum/topic/11798-help/#findComment-142854
  • Member For: 21y 2m 8d
You would be best to get the local suspension place to do the work.
Fitting springs is a piece of cake if you know what you are doing and have the right tools, but the car will need a full wheel alignment after the work is done and you would only save yourself about $100 in labour doing the spings at home.
You also risk damaging your tyres driving it to the wheel place for the alignment if you have not got the wheels close to right.
If you have never done it before, leve it to the experts that have the knowhow, tools and parts. :crybaby:
https://www.fordxr6turbo.com/forum/topic/11798-help/#findComment-142856
  • Member For: 21y
ZZapxr6t
Took your advise and have been to see a "pro" for the install. Quoted $460.oo for install of springs, camber kit, front and rear wheel alignment. Plus he "recommended" that I should replace all the shocks
with bilsteins at approx $1800.00. Me thinks he thinks me stupid or does the $ for fitting sound correct??
Cragin
https://www.fordxr6turbo.com/forum/topic/11798-help/#findComment-142865
  • Member For: 22y 4m 20d
Cragin,
Have you already got the springs etc? I'm wondering if you couldn't get your dealer to do it.... Gregory's have done some Herrod work on my brother's Pursuit. I'm sure they wouldn't be too over the top on labour charges.
Grant
https://www.fordxr6turbo.com/forum/topic/11798-help/#findComment-142868
  • EMS makes MAGIC MUMBO !
  • Member For: 21y 4m 10d
Craign,
I did something very similar (Purchased springs seperate from having them installed) and from memory my installation cost was something like $200-$300 including supply and fit of Camber kit, and wheel alignment. Also a follow up whell alignment a couple of weeks later to make sure nothing changed once it all settled down!
I'd shop around a little bit !
https://www.fordxr6turbo.com/forum/topic/11798-help/#findComment-142869
