HUSTLER Member 663 Member For: 21y 10m 2d Location: Broken Hill Posted 05/07/04 08:03 AM Share Posted 05/07/04 08:03 AM Do the BA GT valve springs fit into the turbo without any adjustemnts??I was trying to source the APS ones for ages, and this is what my aps dealer gave me in the end?!?!?Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/11684-ba-gt-valve-springs/ Share on other sites More sharing options...
Geeseman Donating Members 1,805 Member For: 21y 7m 26d Location: Sydney Posted 05/07/04 08:07 AM Share Posted 05/07/04 08:07 AM I think Bcl has them on his car, so yes. Link to comment https://www.fordxr6turbo.com/forum/topic/11684-ba-gt-valve-springs/#findComment-140763 Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 5m 29d Gender: Male Location: Sydney Posted 05/07/04 08:16 AM Share Posted 05/07/04 08:16 AM No....however, I have them on my car.I was told the head needs some machining for them to fit correctly.Brian Link to comment https://www.fordxr6turbo.com/forum/topic/11684-ba-gt-valve-springs/#findComment-140769 Share on other sites More sharing options...
HUSTLER Member 663 Member For: 21y 10m 2d Location: Broken Hill Posted 05/07/04 10:36 AM Author Share Posted 05/07/04 10:36 AM So you are running them completely as sold bcl??How much machining is suppose to be required?? Link to comment https://www.fordxr6turbo.com/forum/topic/11684-ba-gt-valve-springs/#findComment-140831 Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 22y 3m 5d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 05/07/04 10:57 AM Share Posted 05/07/04 10:57 AM xr8 springs will fit, without machiningScotty Link to comment https://www.fordxr6turbo.com/forum/topic/11684-ba-gt-valve-springs/#findComment-140835 Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 5m 29d Gender: Male Location: Sydney Posted 05/07/04 12:05 PM Share Posted 05/07/04 12:05 PM HUSTLER said: So you are running them completely as sold bcl??How much machining is suppose to be required?? Hustler,Ask Simon at Nizpro.... he'll give you the information.Brian Link to comment https://www.fordxr6turbo.com/forum/topic/11684-ba-gt-valve-springs/#findComment-140860 Share on other sites More sharing options...
bloan Member 379 Member For: 21y 11m 14d Gender: Male Location: Melbourne. Posted 05/07/04 11:57 PM Share Posted 05/07/04 11:57 PM Have been researching this over the past week & can tell you that the only replacement springs available at the moment are the XR8/BA GT or Comp Cams in the states I think make a comparable spring, not cheap though, US$320 for 24 springs excl. postage as compared with the BA GT springs $6.16+GST ea.. Not sure if the XR8/GT springs are the same spec. as the Comp Cams springs though?I did ring Crow Cams & they are getting springs made, but told me they will be another 2-3 months away, they also confirmed that XR8/GT springs are the only local option at the moment! Link to comment https://www.fordxr6turbo.com/forum/topic/11684-ba-gt-valve-springs/#findComment-140918 Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 22y 3m 5d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 06/07/04 01:30 AM Share Posted 06/07/04 01:30 AM bloan said: Not sure if the XR8/GT springs are the same spec. as the Comp Cams springs though? The XR8 springs can be fitted whilst the heads remain on the car & trade for around $8.20 a pop. 56 odd pound on the seat, 160 odd on the nose with 100 thou clearance before coil bindScotty Link to comment https://www.fordxr6turbo.com/forum/topic/11684-ba-gt-valve-springs/#findComment-140936 Share on other sites More sharing options...
cuspub Greg Brindley Member 97 Member For: 21y 10m Location: Melbourne Posted 06/07/04 02:11 AM Share Posted 06/07/04 02:11 AM Nizpro has its own springs (designed to cater for both stock and high lift camshafts) with a retail price of $260 inclusive of GST.They're manufactured with less coils (for high lift applications) and via thicker material have a higher rate. They fit directly without any modification what so ever.ktford is right in that they can be fitted while the head is still in place, however it is a laborious job (irrespective of what spring you use) and should only be carried out using the factory Ford tool. But even with this tool you are still looking at between 5 - 6 hours to fit the springs.Greg Brindley. Link to comment https://www.fordxr6turbo.com/forum/topic/11684-ba-gt-valve-springs/#findComment-140946 Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 4m 22d Gender: Male Location: Sydney Posted 06/07/04 08:02 AM Share Posted 06/07/04 08:02 AM Thanks for the info Greg. Link to comment https://www.fordxr6turbo.com/forum/topic/11684-ba-gt-valve-springs/#findComment-141058 Share on other sites More sharing options...
