minstral Member 115 Member For: 20y 8m 19d Location: Melbourne Posted 01/07/04 09:46 AM Share Posted 01/07/04 09:46 AM APS also quoted "there is still no need to replace the stock XR6T con rods unless you plan to exceed 330RWkW" read a little closer Link to comment Share on other sites More sharing options...
aps Member 1,505 Member For: 22y 6d Posted 01/07/04 09:50 AM Share Posted 01/07/04 09:50 AM Peter, Your original quote clearly stated:It has little to do with the power increasenow you say:unless you are planning on going above 330 RWkWsso what was previously unqualified is now qualified.I have no problem with the advice now being updated, so don't get too hung up over it.BrianI still have not yet seen a XR6T con rod failure that could be attributed to high power, I believe the piston will fail first..........then the con rod is unsupported...............lets deal with the facts. :lol: I am recommending stronger con rods for safety reasons only............have a look at the C and V XR6T engine............over 400 RWkW's and has run a 10.98 pass (quickest in Australia) and guess what.............stock con rods and pistons. These are the facts not speculation. RegardsPeter Link to comment Share on other sites More sharing options...
Blown BA In Your Face Member 6,195 Member For: 22y 4d Gender: Male Location: Peninsula Posted 01/07/04 09:53 AM Share Posted 01/07/04 09:53 AM I still have not yet seen a XR6T con rod failure that could be attributed to high power Hey Peter didn't your mate STREET TUNER say that he has seen con rod failure on an XRT....mind you he does seem to know everything Link to comment Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 21y 6m 23d Gender: Male Location: NSW Posted 01/07/04 10:03 AM Share Posted 01/07/04 10:03 AM I still have not yet seen a XR6T con rod failure that could be attributed to high powerHey Peter didn't your mate STREET TUNER say that he has seen con rod failure on an XRT....mind you he does seem to know everything :lol: Link to comment Share on other sites More sharing options...
aps Member 1,505 Member For: 22y 6d Posted 01/07/04 10:04 AM Share Posted 01/07/04 10:04 AM (edited) I still have not yet seen a XR6T con rod failure that could be attributed to high powerHey Peter didn't your mate STREET TUNER say that he has seen con rod failure on an XRT....mind you he does seem to know everything What would a journalist know about engine diagnosing? :lol: Sorry Martin. :lol: PeterAPS Edited 01/07/04 10:05 AM by aps Link to comment Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 21y 6m 23d Gender: Male Location: NSW Posted 01/07/04 10:06 AM Share Posted 01/07/04 10:06 AM Carefull guys you may awaken the quiet Street Tuner Link to comment Share on other sites More sharing options...
cuspub Greg Brindley Member 97 Member For: 21y 6m 19d Location: Melbourne Posted 01/07/04 11:20 AM Share Posted 01/07/04 11:20 AM Interesting banter guys.Peter, I suspect that you base your opinion on rod integrity because you have never had a problem with them, therefore it is quite a logical thought to suggest that there is not need to change then.Unfortunately Nizpro has had to rebuild quite a number of engines for the simple reason that rods either bend or let go with power levels - in some cases - of no more than around 300 rwkw. Why? Because no engine is the same, and it must be stated that QC with the XR6 Turbo is certainly lacking. Core shift as alluded to in this thread, is prevalent, and in some cases Nizpro has seen engines whereby the No 1 cylinder wall thins down to just 1.6mm. Not good if you intend increasing boost!I have attached an image of a bent rod from an engine recently sent down from Queensland (it came down surrounded by the rest of the engine I should add), I could also show you images of knackered bearings (the failure for which I am not going to explain as it will provide some with answers that they need to work out for themselves) that have come out of engines with just 2000k on the clock, but which are almost unserviceable - perhaps partly as a consequence of every engine being different, poor quality control and so forth.Four (4) blueprinted, billet rod and forged piston equipped engines have gone out the door in the past week, another is about to land from Dandenong, as is one from Tasmania and another from S.A. Why are all of these engines coming to Nizpro? Because the rods and or bores and or bearings are failing.Finally, we have not seen any engines that from memory have suffered piston breakage. This normally comes down to tuning - read detonation.Greg Brindley. Link to comment Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 21y 11m 10d Gender: Male Posted 01/07/04 03:53 PM Share Posted 01/07/04 03:53 PM Thanks Cuspub, that info is worth heaps to me. Will spend the 2k for custom rods. Link to comment Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 21y 11m 24d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 01/07/04 08:34 PM Share Posted 01/07/04 08:34 PM have a look at the C and V XR6T engine............over 400 RWkW's and has run a 10.98 pass (quickest in Australia) and guess what.............stock con rods and pistons. Hey Peter,is it posible to get an update on how many K's the CnV car & your own have done with these power levels?Scotty Link to comment Share on other sites More sharing options...
IM2QIK Member 84 Member For: 21y 3m 20d Posted 01/07/04 10:59 PM Author Share Posted 01/07/04 10:59 PM I am recommending stronger con rods for safety reasons only............have a look at the C and V XR6T engine............over 400 RWkW's and has run a 10.98 pass (quickest in Australia) and guess what.............stock con rods and pistons. These are the facts not speculation. RegardsPeter Hey Peter,Thanks for the "only for SAFETY recommendation regarding upgrading the rods" and also reminding me the rods lasted the 10.98 second distance in the C&V car ....Very reassuring Link to comment Share on other sites More sharing options...
