Jamie XR6 Member 190 Member For: 22y 28d Location: Sydney Posted 02/07/04 11:59 AM Share Posted 02/07/04 11:59 AM macka said: What's your thought's I plan to have the Xede done next week would it be best to have CAI done before this or does'nt matter I don't think it would really matter. Link to comment https://www.fordxr6turbo.com/forum/topic/11593-finished-first-mod/page/3/#findComment-139963 Share on other sites More sharing options...
CHIPS Great rack Donating Members 1,351 Member For: 22y 1m 8d Gender: Male Location: Geelong Vic. Posted 02/07/04 12:05 PM Share Posted 02/07/04 12:05 PM turb06 said: The guys using the xr8 under headlight induction setup. Are you guys keeping the original airbox from your T and just adding another peice to run to the air box, or are you using the xr8 airbox also?Sorry if this sounds like a dumb question I'm just having trouble picturing what you mean.Yeh, using the whole XR8 setup, then adding the Turbo snorkel back on.Ala Jamie XR's photo's Link to comment https://www.fordxr6turbo.com/forum/topic/11593-finished-first-mod/page/3/#findComment-139964 Share on other sites More sharing options...
macka'sxr6t Member 1,480 Member For: 20y 11m 6d Location: Mildura Posted 02/07/04 12:10 PM Author Share Posted 02/07/04 12:10 PM Jame XR6, That's exactly what I want. If it's not a rode ? what did this cost you from Ford dealer and did you need any other brackets to bolt filter body to body work. Did you feel any improvement in throttle responce? I'll order one tommorow. Link to comment https://www.fordxr6turbo.com/forum/topic/11593-finished-first-mod/page/3/#findComment-139965 Share on other sites More sharing options...
CHIPS Great rack Donating Members 1,351 Member For: 22y 1m 8d Gender: Male Location: Geelong Vic. Posted 02/07/04 12:10 PM Share Posted 02/07/04 12:10 PM Jamie XR6 said: macka said: What's your thought's I plan to have the Xede done next week would it be best to have CAI done before this or does'nt matterI don't think it would really matter. I think it might make some diference, because you may have to have your car re-tuned after the CAI setup. - I think it best to do it first.Mark. Link to comment https://www.fordxr6turbo.com/forum/topic/11593-finished-first-mod/page/3/#findComment-139966 Share on other sites More sharing options...
jetute Donating Members 4,553 Member For: 21y 3m 2d Gender: Male Location: brisbane Posted 02/07/04 12:38 PM Share Posted 02/07/04 12:38 PM turb06 said: The guys using the xr8 under headlight induction setup. Are you guys keeping the original airbox from your T and just adding another peice to run to the air box, or are you using the xr8 airbox also?Sorry if this sounds like a dumb question I'm just having trouble picturing what you mean. yep... original box... 56mainline was the first one (as far as im aware??) to do this... if you flick through his posts you will see pictures of the set up (and a guide on how to do it... took me about an hour... very neat, very factory, very cheap and definately gained a couple a ponies Link to comment https://www.fordxr6turbo.com/forum/topic/11593-finished-first-mod/page/3/#findComment-139972 Share on other sites More sharing options...
macka'sxr6t Member 1,480 Member For: 20y 11m 6d Location: Mildura Posted 02/07/04 12:47 PM Author Share Posted 02/07/04 12:47 PM jetute, Do you think that there would be any throttle response gain using XR8 pod & filter compared to the original XR6 box using a BMC filter.Or would it be better to find a way to push more air into original box with BMC filterIt's the actual filter that gives you gain from what I seen from my dyno results. Link to comment https://www.fordxr6turbo.com/forum/topic/11593-finished-first-mod/page/3/#findComment-139974 Share on other sites More sharing options...
Jamie XR6 Member 190 Member For: 22y 28d Location: Sydney Posted 02/07/04 12:55 PM Share Posted 02/07/04 12:55 PM macka said: Jame XR6, That's exactly what I want. If it's not a rode ? what did this cost you from Ford dealer and did you need any other brackets to bolt filter body to body work. Did you feel any improvement in throttle responce? I'll order one tommorow. I bought my set up at cost price from Ford and the adapter from BPT.It takes very little to fit. I had to drill two holes in the body to secure the filter and that was it.I also had to cut a 83mm hole in the side of the filter housing to mount the adapter to the XR6 snorkle.If you dont want the hassle, buy BPTs as it already comes with the hole in the filter.He will even send you instructions on how to fit it. Barry sends all his gear COD and is very friendly and helpfull if you need to ask questions. Link to comment https://www.fordxr6turbo.com/forum/topic/11593-finished-first-mod/page/3/#findComment-139975 Share on other sites More sharing options...
macka'sxr6t Member 1,480 Member For: 20y 11m 6d Location: Mildura Posted 02/07/04 01:08 PM Author Share Posted 02/07/04 01:08 PM Thanks Jamie XR6,Did you feel the car had better throttle responce. (Barry claims 10 rwkw) compared to original box. And did you try a better quality filter like BMC in the original air box before changing to your new setup?Neil Link to comment https://www.fordxr6turbo.com/forum/topic/11593-finished-first-mod/page/3/#findComment-139980 Share on other sites More sharing options...
Jamie XR6 Member 190 Member For: 22y 28d Location: Sydney Posted 02/07/04 01:17 PM Share Posted 02/07/04 01:17 PM (edited) macka said: Thanks Jamie XR6,Did you feel the car had better throttle responce. (Barry claims 10 rwkw) compared to original box. And did you try a better quality filter like BMC in the original air box before changing to your new setup?NeilYes there is better throttle response and the engine seems to rev a lot easier.I'd definitely recommend the BMC filter for it as well.I know Barry's claim of 10 rwkws was for a XR8 with the adapter. Not sure what it does for the XR6T but it's possible that it could be around the same mark. I would say around the 5-7 kw mark.A few of the guys on here have also adapted the XR8 snorkle to fit the standard XR6T airbox as well. Edited 02/07/04 01:18 PM by Jamie XR6 Link to comment https://www.fordxr6turbo.com/forum/topic/11593-finished-first-mod/page/3/#findComment-139984 Share on other sites More sharing options...
Jamie XR6 Member 190 Member For: 22y 28d Location: Sydney Posted 02/07/04 01:20 PM Share Posted 02/07/04 01:20 PM macka said: And did you try a better quality filter like BMC in the original air box before changing to your new setup?Neil Yes I had a BMC panel filter in mine before I changed to the XR8 filter.I honesly couldnt say that I felt a difference, just a little more induction noise so there was definitely better airflow Link to comment https://www.fordxr6turbo.com/forum/topic/11593-finished-first-mod/page/3/#findComment-139986 Share on other sites More sharing options...
