  • Member For: 21y 1m 20d
As my black bird is leased I am limited as to the modifications. I have already replaced the original snorkel with a T snorkel (Its a NA - sorry) and will get a KN panel filter soon. The only other mod(s) that I can think which will allow me to return the car to stock without hassels relate to reducing engine bay heat - so any suggestions/recomendations
1. ? Heat shielding tape on exhaust and intake pipes
2. Heat shield for the air box (Has anybody done this)
3. ?? maybe piping some colder air to the mouth of the snorkel - not sure if this will help
4. ? a 12 volt exhaust fan system to remove the "hot air" - Some of the computer fans are quite powerful - 3-4 of these may reduce under bonnet heat
5????
As I said any suggestions etc most welcome
:kissmy::gooff:
newxr
https://www.fordxr6turbo.com/forum/topic/11476-heat-shielding/
  • Member For: 21y 9m 29d
I don't think reducing under bonnet heat is going to give you much of an effect on driver experience. Getting cold air to your intake is probably the best and cheapest mod with out installing an exhaust system.
  • Member For: 21y 4m 15d
I think newxr is talking about venting the heat to prevent paint damage and evethough his is an na its the turbos we need to worry about as they would get much hotter but he has a point I have already heard of plastic melting and paint peeling , how stupid of ford not to put vents.
My thoughts exactly newxr I think bonnet vents are the way togo but which ones is the drama.
regards
stang
  • Member For: 22y 2m 1d
I agree the T's should have bonnet vents.....it's only a matter of time before after market ones start appearing on cars
Goldies is a pretty good example I reckon.... :k24t:
  • Former XT pilot
  • Member For: 21y 10m 12d
Not that true, that's because of a sh*t paint job.
Goldie has painted the actual turbo charger with the 2 pack paint (same as the car) and it hasn't even started to flake/peel.
  • Flaccid Member
  • Member For: 22y 14d
still, vents would be a good Idea...Went to a track day and It was easy to spot all the T's, they had thier bonnets up in the pits!
