galapogos01 Donating Members 13 Member For: 17y 4m 19d Posted 24/01/09 07:45 AM Share Posted 24/01/09 07:45 AM any chance of another link to the sensor and display setup? the link to ls1 forums requires membership... Link to comment https://www.fordxr6turbo.com/forum/topic/11386-intake-temps/page/3/#findComment-809514 Share on other sites More sharing options...
SLY6T Donating Members 585 Member For: 17y 9m 4d Gender: Male Location: vic , melb SE Posted 24/01/09 08:31 AM Share Posted 24/01/09 08:31 AM any of you guys tried water/meth intercooler spray ? . iv basicly got a custom set up ready to go on my ute just have to fine time to fit it all . Link to comment https://www.fordxr6turbo.com/forum/topic/11386-intake-temps/page/3/#findComment-809553 Share on other sites More sharing options...
BeerTurbo Donating Members 241 Member For: 6y 11m 26d Posted 25/04/22 02:36 AM Share Posted 25/04/22 02:36 AM I'm just going to bump this old thread here. My turbo territory with its stock top mount intercooler would heat soak easily, when accelerating from a standstill it would go from ambientish to around 85 deg c by the time you at 110kph / end of third. after installing a 400x600x76 core front mount the intake temps would basically match ambient temp . the same 0-110 test and it would barely raise 5 degrees c. turbo r31 barra with no intercooler, temp when no boost is anywhere from 40 to 55 deg c, as soon as the boost hits + 800 ish-rpm it will be over 85 deg c. this has water meth injection and the current setup sees consistent low 60deg c when turned on and car on boost. a falcon will usually start to pull timing after 100 deg F / 38 deg c, then ramp this up after 150deg f / 65degc. so ideally you want your charge temp to be below 38deg c to maintain power levels. Link to comment https://www.fordxr6turbo.com/forum/topic/11386-intake-temps/page/3/#findComment-1711711 Share on other sites More sharing options...
Typhoon Member 564 Member For: 20y 7m 12d Gender: Male Posted 25/04/22 08:14 AM Share Posted 25/04/22 08:14 AM 🥱 Link to comment https://www.fordxr6turbo.com/forum/topic/11386-intake-temps/page/3/#findComment-1711715 Share on other sites More sharing options...
