mattpwc Member 51 Member For: 20y 10m 28d Location: New Zealand Posted 15/06/04 06:09 AM Share Posted 15/06/04 06:09 AM Hey guys< im in Nz and have just taken delivry of my new pride and joy, my previous was an au2 xr6 and when I fitted it with extractors, a k & n and went from using 91octane to 98octane I gained roughly 30kw and my fuel economy got better by about 25% due to better breathing and more power per stroke, is this not the case with the turbo? your thoughts are appriciated Link to comment https://www.fordxr6turbo.com/forum/topic/11330-kn-filter/page/2/#findComment-134189 Share on other sites More sharing options...
Guest dingah Guests Posted 15/06/04 06:44 AM Share Posted 15/06/04 06:44 AM Hmm mattpwc, more air through the filter means higher not lower fuel consumption as in order to retain the correct air/fuel ratio more air requires more fuel. THe combination of the two gives slightly more power, however. Logically better fuel consumption should be a fallacy. Maybe due to less weight in the wallet?Cheers,Dingah Link to comment https://www.fordxr6turbo.com/forum/topic/11330-kn-filter/page/2/#findComment-134210 Share on other sites More sharing options...
teebone Member 183 Member For: 21y 6m 2d Location: South of Melbourne, near the sea Posted 15/06/04 08:22 AM Share Posted 15/06/04 08:22 AM fitted a BMC panel filter @ $135 dolllars to replace my dirty 30K km original fitment a couple of weeks back (probably didnt really need replacing but was a good excuse).Cant say I notice any difference in fuel economy but I only really use the Ave reading and havent re-set since fitting the BMC (13L/100Km). Also I have never heard this blow-off and flutter or induction noise that people refer to either before or after fitting (perhaps coz mines an auto?).The T does now seem a bit more responsive in the mid-range at part throttle.My view is that it's probably debatable value at $135 to replace a filter in a new T but a worth while upgrade at 30K kms plus, once the original is getting dirty and loosing it's flow capacity.Havent tried the XR8 2nd CAI mod yet - anyone know how much a new airbox bottom is to replace if you stuff it up or don't like it? Link to comment https://www.fordxr6turbo.com/forum/topic/11330-kn-filter/page/2/#findComment-134237 Share on other sites More sharing options...
Pretzel EMS makes MAGIC MUMBO ! Member 192 Member For: 21y 4m 22d Location: Melbourne Posted 15/06/04 12:57 PM Share Posted 15/06/04 12:57 PM The way I understand fuel consumption with reduced inlet restriction (Read better filter) is that assuming you don't make any allowance for more air/fuel, causing more power, therefore greater road speed, that consumption would increase. But the fact that it is then breathing better, you need to back off the throttle (It might only be a couple of percent) which means the car is now doing the same speed as before, but with a small percentage less throttle.ie. Before say 50% throttle to hold X KM/HrAfter possibly only 48% Throttle to hold the same X KM/HrAs long as my understanding is correct, putting in a panel filter should increase the enonomy slighly !This of course doesn't take into consideration the computer compensating for and measuring the increased airflow ! Does anybody know how the computer works out it's A/F ratio ? Does it work off Throttle Position, or would it just take a reading at the Oxy sensor and compensate for a leaner mixture ? If this is the case ignore my ramblings from above and I'll just see what happens in the next couple of weeks when I fit one myself ! Link to comment https://www.fordxr6turbo.com/forum/topic/11330-kn-filter/page/2/#findComment-134316 Share on other sites More sharing options...
rainy Member 181 Member For: 21y 11m 20d Location: central coast Posted 18/06/04 01:50 AM Share Posted 18/06/04 01:50 AM plonky said: berach of EPA regulations. whats a berach Link to comment https://www.fordxr6turbo.com/forum/topic/11330-kn-filter/page/2/#findComment-134426 Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 22y 1m 17d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 18/06/04 03:01 AM Share Posted 18/06/04 03:01 AM rainy said: plonky said: berach of EPA regulations.whats a berach Don't worry he's just using Goldie's dictionaryScotty Link to comment https://www.fordxr6turbo.com/forum/topic/11330-kn-filter/page/2/#findComment-134441 Share on other sites More sharing options...
