  • Member For: 21y 1m 7d
  vik351 said:
  Chris xr6 said:
  vik351 said:
XR6ikness,so tell us what you actually did,30 minutes? I hope your fly stayed up all that time. :lol:
When you take the hose off and expose the TB,what sort of crap is on it? where does it come from,K@N filter perhaps,thank
vik
Vik it comes from crankcase vapour which is routed back into the manifold right before the throttle body
Shouldnt we put the PCV returne after the TB then?
vik
Only problem that oil vapour drastically alters air fuel ratios we could then end up with and intake full off oil vapour, plumbing this before the tb also ensures that it is evenly distributed between all cylinders (but so would a inlet just after the throttle body)
  • Replies 35
  • Member For: 21y 5m 16d
Hi all,
The throttle body DEFINITELY isn't the problem ... I've had the throttle body replaced with a new unit and my car still stalled the very next day!! :blush:
I've replaced the Canister Purge Valve Solenoid, Throttle Body, Throttle Pedal Assembly and the Engine Wiring harness in that order with 2-3 weeks driving between each item being replaced to see if there's any real difference yet my car still STALLS! My dealers shortly replacing the PCM with a new unit to see if that resolves this issue!
Luckily I've a very helpful dealer who's determined to find the source of this very annoying problem despite my car never stalling WHILST he's driven it!
Will inform everyone if I rectify this issue :cussing:
  • FORD FORD FORD
  • Member For: 22y 1m 20d
Maybe you got another issue as well as
Scotty
Hey Scotty,
Yeah maybe I have another issue ... BUT funny how my symptoms are the same as everone elses. Like Jeff I've had all the PCM Reflashes and the Canister Purge Valve Solenoid replaced but to no avail.
Surely a little oily film from the crankcase breather should'nt hinder the throttle bodys performance to the extent the car stalls?
My new Throttle Bodys been in use 3 months now and I've just pulled it off ... there's only an ever so slight oily residue ... nothing really ...
Many other brands of new cars have the Crankcase vented before the throttle body but dont stall :huh:
Best of luck to anyone carrying out this new FORD TSB on cleaning the Throttle Body to fix the stalling :huh:
I think I'll just add this to my FORD TSB's WITCH DOCTOR VOO DOO LIST to fix the stalling problem being Canister Purge Valve Solenoid, PCM B30 Reflash and now Throttle Body cleaning :gooff:
cheers
  • 11 months later...
  • Member For: 20y 7m 28d
dunno where all these old posts come from all of a sudden but the solution is get dealer to replace the TPS (throttle position sensor) in the throttle body.
  • My new toy
  • Member For: 22y 15d
<{POST_SNAPBACK}>
Done this twice still stalls and runs rough at idle real got at round abouts. :laughing:
All so cleaned throttle body no difference.
Ian
  • Member For: 22y 3m 11d
Ian.
So I assume from your comments that the 02 sensor did not fix your problem that you replaced ages ago to try and fix this crap,Shame as this was going to my next step.
I might go back to the pedal box I think not giving a idle position reading maybe.I can get my ute to stall everytime on a steep corner just as I come to a stop the idle will drop way down then stall.
Failing this I wonder if a new one of these idle edit mapps can be loaded in.I am not after anymore power just a bloody car that does not stall.
