  • My new toy
  • Member For: 22y 21d
Rednut he is right cutting into the booster hose is classed as unroadworthy[illeagal] as if it were to come adrift you would have very little brakes.
Ian
  • Replies 138
  • FPV521
  • Member For: 20y 8m 8d
  rednut99 said:
Well I just had the service last night, cost me friggin $357 for an oil change, they checked every single thing on the car from filters to brakes to tyres to ECU.
I ended up with the new ECU software (post overboost), noticed stuff all difference except that she seemed to be much more responsive off idle, more torquey.  :spoton:
Fuel tank got removed and adjusted straps so that the fuel filler was accessible.
Colour coded door trim was peeling again, instead of glueing it they ordered a new one and need to get it painted and glued on later in the week.
The front brakes got machined.
And the powersteering shudder is normal (my arse!)
And the service manager spent 10 mins grilling me about the location of my Hobbs switch (pressure sender). I had it spliced into the brake booster line. He said it was highly dangerous and illegal and my insurance was void (but not my warrenty [oh yay]). It even states in writing on my service report that it was illegal and had to removed from the car the next day. It will cause an accident. The service manager said he races turbo's outside of Ford and reckons its the worse place to have it. He suggest tapping into the alluminium crossover instead.
So I have ordered a new brake booster line for $15 (comes in Thurs) and will atempt to fit that before I go away for the weekend.  :w00t2:
I am still unsure if this manager actually cared about what he was telling me or was just cut because my Turbo was 'slightly' modified. Ah well.  :ermm:
Anyone else had crap like this?  :w00t2:
<{POST_SNAPBACK}>
I cant believe the power steering shudder is still happening. I had a 1994 XR and had a heap of problems gettig that sorted. Cant remember how they fixed it but that was back in 94 !!!!!!
  • Member For: 22y 3m 25d
I had my dealer try to tell me that my center pipes (deletion of the centre muffler) would void my warrenty...
I now go to a different dealer.
Dave.
  • Dark Knight Mafia Member No. - 666
  • Member For: 22y 2m 18d
My dealer didnt give 2 sh*ts about my boost guage being tapped into the brake booster, then again I dont think I will ever come off, we used heaps of loctite and 2 clips either side.
As for the centre muffler chop he said they will no longer warrant that section of exhaust or the heat shield around that section (becasue of excess noise vibration working it loose.) fairs fair, and that's what I expected. But I will tell them in advance about the unichip just to let them know.
Dazza.
  • FPV521
Dave.
<{POST_SNAPBACK}>
Cant say I blame you :spoton:
  • Member For: 21y 10m 24d
I feel that I should relocate it. It cost bugger all to replace the hose, and I will take my time sussing out the right tools and parts needed to tap into the crossover. I believe It would read more accurate there anyway.
I guess I will need an 8mm spur with a tapered thread, 8mm drill bit, 8mm tap and di, some braded hose ( I know where I have some of that spare LOL!). And some spare time to remove the cross over and mount the flucker!
  • - Track Bound EVO III -
  • Member For: 20y 4m 28d
Mate, seriously, you tapped your brake booster for a vacum feed??
my opinion, good on u for listening, and $15 and some time is worth it..
:blush:
  • Flower Power
  • Member For: 22y 7m 3d
:blush:
<{POST_SNAPBACK}>
A lot of us have for the fairmont type boost guage. The instructions tell you to do this.
  • still kicking around
  • Member For: 22y 1m 21d
Dad is getting :spoton: pissed off, because our dealer won't fix anything, we got brake shudder, rooted gearbox, diffwhine, power sterring shudder and they say they can't see anything wrong so dad is oging to take it up with ford themselves
