FORDTECH Member 383 Member For: 21y 9m 9d Location: On the edge Posted 09/06/04 10:25 AM Share Posted 09/06/04 10:25 AM Here we go again !!!!My apologies.I forgot that you're a service advisor. Link to comment Share on other sites More sharing options...
SR-71 Blackbird Member 235 Member For: 21y 4m 3d Location: Mount Isa Queensland Go the Maroons Posted 09/06/04 11:08 PM Author Share Posted 09/06/04 11:08 PM Hi Fordtech,Ive recently upgraded my wheels to 19's.Would I need to have any changes made to the program on my ECU?thanksGeesemanThere isn't an option in the list of preset wheel sizes on the WDS for 19's.You will probably find that the wheel height and rolling diameter of your new wheels isnt that much different to the original wheels anyway.As I posted before the performance difference would be minimal as well. I have 19's 4% speedo difference and 1 inch higher ride height. Asked the servicing dealer to recalibrate the speedo they said they did. Fordtech how can this be done can it be done on the car computer or does it require a third piece of equiptment say a gps to get an accurate speed to reference to? Link to comment Share on other sites More sharing options...
SR-71 Blackbird Member 235 Member For: 21y 4m 3d Location: Mount Isa Queensland Go the Maroons Posted 09/06/04 11:17 PM Author Share Posted 09/06/04 11:17 PM Here we go again !!!!My apologies.I forgot that you're a service advisor. Fordtech I travelled 1000klms to get my car serviced things to be fixed leaking water pump, rattling exhaust shield, whistling door seals, speedo recalibration, revision upgrade. I find it hard to get my car to a reputable service agent and am dissapointed problems can't be fixed. Admittedly they fixed the leaking water pump by replacing it, recalibrated the speedo to the best of my knowledge. but this is the second time they have tightened the exhaust shield and it still rattles and the first time it was in for a service the apprentice had the gall to light it up in the service department as I left. The new revision I have on my car causes it to almost stall when the aircon kicks in the diff backlash is less though. I believe they may have lowered the idle is this a standard part of the reflash or is it set by the dealer when in for a service I did I believe pay a premium for the service at $200.00 even though I supplied the oil and oil filter! Link to comment Share on other sites More sharing options...
FORDTECH Member 383 Member For: 21y 9m 9d Location: On the edge Posted 10/06/04 08:58 AM Share Posted 10/06/04 08:58 AM I have 19's 4% speedo difference and 1 inch higher ride height. Asked the servicing dealer to recalibrate the speedo they said they did. Fordtech how can this be done can it be done on the car computer or does it require a third piece of equiptment say a gps to get an accurate speed to reference to? SR-71Went to work today and checked on the WDS and there is actually an option when programing Axle ratio/Tyre size to put in other dimension wheels.All the dealer does is enter the diameter,profile and section width and it actually gives you the correct rolling diameter to program into the PCM.One thing that may apply to your problem is a TSB that was released this week regarding poor idle and in some instances stalling.It has to do with excessive build up of oil in the throttle body.The TSB number is 36/04.Unfortunately for you is that you need to monitor the PCM using a WDS to see if your vehicle is being affected by this. Link to comment Share on other sites More sharing options...
camerooch Member 129 Member For: 21y 9m 17d Location: Melbourne Posted 10/06/04 09:22 PM Share Posted 10/06/04 09:22 PM Apology accepted.... Link to comment Share on other sites More sharing options...
aaronmihe Upstanding Member Member 759 Member For: 21y 6m 7d Location: Canberra - ACT Posted 15/06/04 01:35 AM Share Posted 15/06/04 01:35 AM Fordtech - would this have occurred 'suddenly' or built up over time? I have got 8 hours booked with the dealerships ECU/BA/WDS legend when he gets back from leave on the 28th. At least they're takign my concerns seriously.I'm starting to think since I did the battery disconnnect power is pretty close to 'normal' (Three Dyno runs on the weekend all at around the 180-190kw mark on a "tough dyno") but it's still cutting out and surging on the road. One of the torque printouts looks like a staircase with steps up the curve!It's definately not running 'right' but it's hard to demonstrate the fault when it's intermittent under yet occurs 90% of the time under certain conditions. I don't expect the tech to drive the car all day trying to trip it up. We'll see what happens, I'm presuming I'll now get the TB cleaned up - probably a reflash to make sure the previous flash wasn't corrupted and a through check of sensors etc via the WDS.... A. Link to comment Share on other sites More sharing options...
richdave SLOJAM, Gone but not forgotten Lifetime Members 1,841 Member For: 22y 5m 1d Gender: Male Location: Outer east - Melbourne Posted 17/06/04 11:31 PM Share Posted 17/06/04 11:31 PM Lets get it back in then - You know I'm not Happy if Your not Happy ?!! And he means it.... Had my car in a few day back and after a throttle body clean and a s/w update the car drives like a new one....even noticed the fuel consumption has improved.... Link to comment Share on other sites More sharing options...
shiftyxr Member 340 Member For: 20y 10m 16d Location: Adelaide Posted 19/06/04 12:24 AM Share Posted 19/06/04 12:24 AM MMMMMMMMMMM oil in throtle body,could this be my blue smoke on cold start overnight? Link to comment Share on other sites More sharing options...
