Xede upgrade review after 30,000kms
Guest 56Mainline
  • Guests
  turb06 said:
I have a question. With either chip upgrade weather that be chiptorque or unichip, if and when ford services your car and upgrades the program on the ECU hopefully for a better one, does this mean you will have to get the chiptorque/unichip chips reprogrammed also.
I didn't have a problem after the 15,000km service.
So, it depends on what the upgrade ECU program is for.
I think the majority of reprogram has been centred around cold start idle, idle particularly with the AC on, automatic shift points, etc. rather than boost or air/fuel ratios.
If the latter occurs, then yea, a dynotune would be necessary.
  • FORD FORD FORD
  • Member For: 22y 1m 27d
  ducatijb said:
Good result 56M...hope to be there myself after the auto upgrade :w00t2:
How many $$$$$$ are you allocating for the auto upgrade?
Scotty CCC
  • FORD FORD FORD
  ducatijb said:
Probably to get the auto done properly will be around the 2k mark
should be quite strong after that
scotty CCC
