chooch Member 256 Member For: 21y 4m 6d Location: Adelaide Posted 02/06/04 06:29 AM Share Posted 02/06/04 06:29 AM Hey guys............I did a search but didnt find a thing. I just replaced all my front globes with artic blue globes but now I need to adjust the beams. I found out how to do adjust the outer lights ok, but have got no idea how to adjust the inners. I need to adjust them becuase at the moment the left had side is up and the right hand side is over to the left..............ITS A sh*t FIGHT!!!!any help would be appreciated.cheers Link to comment https://www.fordxr6turbo.com/forum/topic/11097-adjusting-the-high-beams/ Share on other sites More sharing options...
Turbo6man Lifetime Members 4,084 Member For: 22y 7m 30d Gender: Male Location: South Coast NSW Posted 02/06/04 06:37 AM Share Posted 02/06/04 06:37 AM The details are actually in the handbook as I recall.However if you lift your bonnet and look at the back of the lights you will see the adjuster knobs for the vertical - there is one for each of the two lenses on each side. I found that you needed to adjust the inners up to their max height for the light to be of much use. The outers which are for high/low should be adjusted when on low beam.The horizontal adjustmnet is done via a small hole in the upper radiator support panel - the one that runs across the front of your car - you may need a torch to shine down the holes so you can spot the small Phillips Head screw adjusters. From memory they are towards the outer side of the car. Link to comment https://www.fordxr6turbo.com/forum/topic/11097-adjusting-the-high-beams/#findComment-129524 Share on other sites More sharing options...
JB Forum Superhero Donating Members 3,109 Member For: 21y 6m 14d Location: Eastern Suburbs of Mexico Posted 02/06/04 06:40 AM Share Posted 02/06/04 06:40 AM Turn up the Air Con! :lol: Sorry could'nt help myself Link to comment https://www.fordxr6turbo.com/forum/topic/11097-adjusting-the-high-beams/#findComment-129528 Share on other sites More sharing options...
chooch Member 256 Member For: 21y 4m 6d Location: Adelaide Posted 02/06/04 07:16 AM Author Share Posted 02/06/04 07:16 AM Hey turbo6man.............thanks for the tip but I cant find that philips head screw that you were talking about. Also the 2 adjuster knobs are for the outer lights only. one knob is for verticle the other is horizontal.................non of these adjusters moves the inner high beam at all...............trust me I have been at it all afternoon.I still cant adjust the inner high beams Link to comment https://www.fordxr6turbo.com/forum/topic/11097-adjusting-the-high-beams/#findComment-129541 Share on other sites More sharing options...
Turbo6man Lifetime Members 4,084 Member For: 22y 7m 30d Gender: Male Location: South Coast NSW Posted 03/06/04 10:43 AM Share Posted 03/06/04 10:43 AM OK mate, my memory is failing me as it is a while since I actually did adjust the lights on my son's ute. My best suggestion is to PM Trumpy as he has been playing with his lights the past week and may be able to help you ... Link to comment https://www.fordxr6turbo.com/forum/topic/11097-adjusting-the-high-beams/#findComment-130196 Share on other sites More sharing options...
