BrentS Member 79 Member For: 22y 2m 13d Posted 17/05/04 01:37 AM Share Posted 17/05/04 01:37 AM To any of the techos out there, how easy (or otherwise) and costly would it be for Ford to add variable valve timing to the BOSS engines?It seems that variable valve timing is the way to go for lots of performance engines now, and to my limited knowledge, I think this may be a way around the usual problems of having a strong bottom end, but also maintaining top end power delivery. I think its a given that both the XR8 and GT could do with another few kw, and more linear torque, so maybe this is an option???Just a thought anyway.Cheers.Brent. Link to comment https://www.fordxr6turbo.com/forum/topic/10779-boss-variable-valve-timing/ Share on other sites More sharing options...
Mondie Firm Member Donating Members 2,924 Member For: 22y 5m 29d Location: Adelaide Hills Posted 17/05/04 01:47 AM Share Posted 17/05/04 01:47 AM l am sure the Boss will gain VVT in the future. Ford have kept it back so that it can introduce this as an improvement in coming versions of the engine. The Barra 220 has VVT. Link to comment https://www.fordxr6turbo.com/forum/topic/10779-boss-variable-valve-timing/#findComment-123077 Share on other sites More sharing options...
Ford_Power Member 798 Member For: 22y 30d Posted 17/05/04 04:55 AM Share Posted 17/05/04 04:55 AM (edited) Yes the Barra 220 does have VCT. The reason that the Barra 220 has VCT and the Boss 260 and Boss 290 don't, is because the Barra 220 head was designed from the ground up by Ford Australia. The Boss engines are utilising American sourced heads which do not have the space nor are designed for VCT.The Boss engines use the American spec exhuast cam profile, but the inlet cam profile was developed here by Ford Aust.No doubt, in due time the Boss Heads will have VCT as made by Ford Australia - and when they do, the engines will be great! Just look at what Ford Aust have done with their OWN designed Barra 182 and Barra 240T heads!!Ross Edited 17/05/04 04:56 AM by Ford_Power Link to comment https://www.fordxr6turbo.com/forum/topic/10779-boss-variable-valve-timing/#findComment-123152 Share on other sites More sharing options...
Redhawk ....Time to lay this fairytale aside...... Donating Members 2,657 Member For: 22y 1m 20d Gender: Male Location: In the Ferry on the River Styx, not getting out just yet! Posted 17/05/04 07:15 AM Share Posted 17/05/04 07:15 AM Pity it won't be a moderately priced bolt-on extra! :( Link to comment https://www.fordxr6turbo.com/forum/topic/10779-boss-variable-valve-timing/#findComment-123209 Share on other sites More sharing options...
Cobra potty trained Lifetime Members 1,938 Member For: 22y 5d Gender: Male Posted 17/05/04 09:31 AM Share Posted 17/05/04 09:31 AM the 5.4 has been around for ages .... I can't recall any VCT developement I know there has been a truckload of 3 valve head and VCT development in the modular motors (especially the 4.6) ... the 2005-6 Mustangs are coming out with this configurationnot sure how much Ford Australia have had to do with the 3 valve 5.4 development... if any at all I'm sure I'll be put straight on this real quick ..... if you are a USA Ford fan like I am and know the history of these motors .... you may find it is a bit of a cheek to quote "Australian input" ...... IMHO all is from the USA parts bin .... part Lightning ... part Mustang/Cobra/CobraR .... part whatevermaybe a little cam tuning .... but the Aussie Tech books give credit to the Cobras for the cams too ... got me stumped 2.2c Link to comment https://www.fordxr6turbo.com/forum/topic/10779-boss-variable-valve-timing/#findComment-123264 Share on other sites More sharing options...
Venom XR6 Member 1,460 Member For: 22y 4d Location: Geelong Victoria Posted 17/05/04 10:00 AM Share Posted 17/05/04 10:00 AM The Boss motors won't get VCT until the americans introduce it to the 4 valve heads, which may not even happen. Ford Australia would not be able to design and build it themselves as it would be a massive task. The whole head would have to be redesigned to accomadate it and would need to be cast here as well. One for the too hard and too expensive basket.As for the Barra 220 it is a wholly Ford US designed and built engine. The only development work done by Ford Oz was the exhaust manifolds and assorted packaging bits to accomdate it in the Falcons engine bay, although the Falcon was the first car to use the new engine. Link to comment https://www.fordxr6turbo.com/forum/topic/10779-boss-variable-valve-timing/#findComment-123269 Share on other sites More sharing options...
HSE2 Member 322 Member For: 22y 3m 23d Location: Tasmania Posted 17/05/04 11:54 AM Share Posted 17/05/04 11:54 AM V_XR6 is correct. The barra220 or triton 5.4 VCT is an American designed and built engine. Until the quad cam picks up VCT or VVT the BOSS won't come with that feature. Link to comment https://www.fordxr6turbo.com/forum/topic/10779-boss-variable-valve-timing/#findComment-123325 Share on other sites More sharing options...
Mondie Firm Member Donating Members 2,924 Member For: 22y 5m 29d Location: Adelaide Hills Posted 17/05/04 11:59 AM Share Posted 17/05/04 11:59 AM l stand corrected Link to comment https://www.fordxr6turbo.com/forum/topic/10779-boss-variable-valve-timing/#findComment-123327 Share on other sites More sharing options...
HSE2 Member 322 Member For: 22y 3m 23d Location: Tasmania Posted 17/05/04 12:05 PM Share Posted 17/05/04 12:05 PM Is there an update on ytour situation I should be reading? I note the for sale sign :( Link to comment https://www.fordxr6turbo.com/forum/topic/10779-boss-variable-valve-timing/#findComment-123329 Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 2m 30d Gender: Male Location: Sydney Posted 17/05/04 12:07 PM Share Posted 17/05/04 12:07 PM Id like to think they are currently trialling a VVT BOSS motor in Victoria somewhere, ready to be mated up to a centrifugal supercharger for next years GTHO.......Please Ford, tell me im not dreaming! Link to comment https://www.fordxr6turbo.com/forum/topic/10779-boss-variable-valve-timing/#findComment-123331 Share on other sites More sharing options...
