Guest Big Mick Guests Posted 02/05/04 10:46 AM Share Posted 02/05/04 10:46 AM another way at looking at mick also is 267 rwkw (as dynoed) and a 22% drivetrain loss would come to about 343fwkw....got to be happy with that Hi TBO240,Yeah that's a good point if 22% drivetrain loss with an auto is accurate. There seems to be so much debate about this. I told that the shoot 6 software is supposed to go some way to compensating for the ambient temperature, but it would have been interesting to do a dyno run at Calder last Friday Night. For interest the 267rwkw was recorded at an ambient temperature of 27degC!Cheers,Mick Link to comment Share on other sites More sharing options...
Guest Big Mick Guests Posted 02/05/04 10:49 AM Share Posted 02/05/04 10:49 AM Maybe you've put on 30k's over the easter break, or fuel weightScotty CCC Mmmm, from beers maybe but not eggs, my kids are too fast for me!I'd say definately fuel (half a tank), but I'm not sure what difference things like premium brakes and sound (weight of amp and sub) and leather would make over a standard T either??? Probably minimal but I guess it all adds up.Mick Link to comment Share on other sites More sharing options...
Geeseman Donating Members 1,805 Member For: 21y 3m 9d Location: Sydney Posted 02/05/04 11:51 AM Share Posted 02/05/04 11:51 AM Obviously my gearbox is knackered!! Mines just bounces until I change it!! When you move it into performance mode, you must not change the gears manually. If you do not change them it will function as a normal auto (only 3 spd and rev far higher). As soon as you change manually you must do so from then on for all gears until you put it back into drive Link to comment Share on other sites More sharing options...
HUSTLER Member 663 Member For: 21y 5m 15d Location: Broken Hill Posted 02/05/04 12:24 PM Share Posted 02/05/04 12:24 PM Obviously my gearbox is knackered!! Mines just bounces until I change it!!When you move it into performance mode, you must not change the gears manually. If you do not change them it will function as a normal auto (only 3 spd and rev far higher). As soon as you change manually you must do so from then on for all gears until you put it back into drive OH SHIGHT!! SO IT DOES!!!! wish I knew this b4 I bounced it off every gear down the strip!!! Link to comment Share on other sites More sharing options...
Flukey Seriously Flukey Member Donating Members 4,354 Member For: 20y 10m 15d Gender: Male Location: Melbourne Posted 02/05/04 01:16 PM Share Posted 02/05/04 01:16 PM This is what I did:1. Start engine2. Traction Control Off3. Select Performance Mode (Not Manual Mode)Performance mode??? Is that just plain Auto or am I mssing something? He mans just pushing the stick over to the left but not changing it manually.Once over to the left, you have the first three gears to change through (it's done automatically) and under hard accel the car goes right to (almost) redline through each gear.No need for 4th on the drag stip. that's why I love this site. I learn so much about my car its not funny. Off for a drive now to tryt it Link to comment Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 21y 10m 19d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 03/05/04 12:28 AM Share Posted 03/05/04 12:28 AM Obviously my gearbox is knackered!! Mines just bounces until I change it!!When you move it into performance mode, you must not change the gears manually. If you do not change them it will function as a normal auto (only 3 spd and rev far higher). As soon as you change manually you must do so from then on for all gears until you put it back into drive From memory it still uses 4th but you've got to be flying to get it to do soScotty CCC Link to comment Share on other sites More sharing options...
SR-71 Blackbird Member 235 Member For: 21y 2m 27d Location: Mount Isa Queensland Go the Maroons Posted 03/05/04 12:47 AM Share Posted 03/05/04 12:47 AM A comment from someone relating trap speed to horsepower got me thinking,I took my T down to the weighbridge at the local tip and recorded a race weight of 1840kg (4050lb). The operator looked at me weird when I was wearing my helmet Then used this CALCULATOR to give an estimate of the hp required to the 113mph trap speed I recorded the other night.466hp = 347kw ????Obviously the accuracy of the weighbridge is unknown, but it seems pretty close given what Ford claim & my 110+kg.Mickanother way at looking at mick also is 267 rwkw (as dynoed) and a 22% drivetrain loss would come to about 343fwkw....got to be happy with that How do you work out the drivetrain loss? 22% sounds a little weird? How do you lose more power in the drivetrain as you increase power at the flywheel?Eg. T 240kw less 22%= 187.2kw loss of 52.8KwT 330kw less 22%= 257.4kw loss of 72.6KwT 1000kw less 22%=780kw loss of 220kw Link to comment Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 21y 10m 19d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 03/05/04 12:52 AM Share Posted 03/05/04 12:52 AM A comment from someone relating trap speed to horsepower got me thinking,I took my T down to the weighbridge at the local tip and recorded a race weight of 1840kg (4050lb). The operator looked at me weird when I was wearing my helmet Then used this CALCULATOR to give an estimate of the hp required to the 113mph trap speed I recorded the other night.466hp = 347kw ????Obviously the accuracy of the weighbridge is unknown, but it seems pretty close given what Ford claim & my 110+kg.Mickanother way at looking at mick also is 267 rwkw (as dynoed) and a 22% drivetrain loss would come to about 343fwkw....got to be happy with that How do you work out the drivetrain loss? 22% sounds a little weird? How do you lose more power in the drivetrain as you increase power at the flywheel?Eg. T 240kw less 22%= 187.2kw loss of 52.8KwT 330kw less 22%= 257.4kw loss of 72.6KwT 1000kw less 22%=780kw loss of 220kw On a sliding scale the percentage loss wil decreaseScotty CCC Link to comment Share on other sites More sharing options...
geea Site protagonist Lifetime Members 4,320 Member For: 21y 8m 24d Gender: Male Location: At the lights, waiting for you. Posted 03/05/04 04:14 AM Share Posted 03/05/04 04:14 AM Mick, would you be able to post your dyno graph?Geea. Link to comment Share on other sites More sharing options...
NT TURBO Member 1,128 Member For: 21y 10m 21d Gender: Male Location: Darwin NT Posted 03/05/04 04:34 AM Share Posted 03/05/04 04:34 AM 4 SPEED PERFORMANCE MODE!!!!! you just wont get 4th till 150k's plus. Link to comment Share on other sites More sharing options...
