SR-71 Blackbird Member 235 Member For: 21y 5m 24d Location: Mount Isa Queensland Go the Maroons Posted 29/04/04 12:28 PM Share Posted 29/04/04 12:28 PM Peter could you please comment on this thread?http://www.mrtrally.com.au/forums/topic.asp?TOPIC_ID=13315Also I am interested most people on this forum are under the impression that interceptors can be a stealth install. Doesn't the Ford ECU register fault codes for overboost and other adjustments. Even though the service department may say nothing about the fault codes they may still be aware the vehicle is modified. Link to comment https://www.fordxr6turbo.com/forum/topic/10445-unichip/ Share on other sites More sharing options...
aps Member 1,505 Member For: 22y 1m 26d Posted 29/04/04 12:41 PM Share Posted 29/04/04 12:41 PM The unichip clamps this signal so the Ford computer only sees a stock boost signal, the Unichip wont cause a fault code to be recorded in the Ford PCM. We check for fault codes after the unichip install and I have not a seen an overboost fault code on a customers xr6t. PeterAPS Link to comment https://www.fordxr6turbo.com/forum/topic/10445-unichip/#findComment-116629 Share on other sites More sharing options...
SR-71 Blackbird Member 235 Member For: 21y 5m 24d Location: Mount Isa Queensland Go the Maroons Posted 29/04/04 01:45 PM Author Share Posted 29/04/04 01:45 PM Do you have acess to a WDS to check fault codes. Link to comment https://www.fordxr6turbo.com/forum/topic/10445-unichip/#findComment-116639 Share on other sites More sharing options...
SR-71 Blackbird Member 235 Member For: 21y 5m 24d Location: Mount Isa Queensland Go the Maroons Posted 29/04/04 01:46 PM Author Share Posted 29/04/04 01:46 PM http://www.vishnutuning.com/xede_evo.htmIs this article incorrect? Link to comment https://www.fordxr6turbo.com/forum/topic/10445-unichip/#findComment-116640 Share on other sites More sharing options...
SR-71 Blackbird Member 235 Member For: 21y 5m 24d Location: Mount Isa Queensland Go the Maroons Posted 29/04/04 01:58 PM Author Share Posted 29/04/04 01:58 PM aps said: The unichip clamps this signal so the Ford computer only sees a stock boost signal, the Unichip wont cause a fault code to be recorded in the Ford PCM. We check for fault codes after the unichip install and I have not a seen an overboost fault code on a customers xr6t. PeterAPS What differences to the engine management system occur? As stated APS users who have modded injectors can no longer believe the DTE (Distance to empty)computer which to me shows the ecu still see an injector duty cycle but cannot and do not compensate for the larger cc's of the injector. Won't the computer become confused as in the 5psi is clamped output. waste gate controls would be different temperatures etc. etc. Does the Unichip allow mapping and corresponding formulas to allow scaling ratios or is the 5PSi just clamped as the throttle is depressed. Surely this would be recorded as a fault. What happens in an overboost situation how does the unichip save the engine. Does the unchip use the knock sensors on the vehicle. Link to comment https://www.fordxr6turbo.com/forum/topic/10445-unichip/#findComment-116642 Share on other sites More sharing options...
aps Member 1,505 Member For: 22y 1m 26d Posted 29/04/04 10:33 PM Share Posted 29/04/04 10:33 PM SR-71 Blackbird said: Do you have acess to a WDS to check fault codes.Yes we do. :lol: PeterAPS Link to comment https://www.fordxr6turbo.com/forum/topic/10445-unichip/#findComment-116682 Share on other sites More sharing options...
aps Member 1,505 Member For: 22y 1m 26d Posted 29/04/04 11:05 PM Share Posted 29/04/04 11:05 PM SR-71 Blackbird said: Is this article incorrect?Mate I dont get concerned with what a JOURNALIST with approx 2 years of business experience has to say, I will leave it at that. What I do know is that the Unichip can handle nearly all of the latest BOSCH motronic engine management systems (Porsche, BMW, Mercedes, etc., etc) the question is what other brand of interceptors can? :lol: PeterAPS Link to comment https://www.fordxr6turbo.com/forum/topic/10445-unichip/#findComment-116698 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 7d Gender: Male Location: Victoria Posted 29/04/04 11:28 PM Share Posted 29/04/04 11:28 PM SR-71 Blackbird said: Also I am interested most people on this forum are under the impression that interceptors can be a stealth install. Doesn't the Ford ECU register fault codes for overboost and other adjustments. Even though the service department may say nothing about the fault codes they may still be aware the vehicle is modified. Mr Blackbird,If you want proof read this thread...How Detectable Are Unichips?, Can they be easily found by dealers? Link to comment https://www.fordxr6turbo.com/forum/topic/10445-unichip/#findComment-116711 Share on other sites More sharing options...
aps Member 1,505 Member For: 22y 1m 26d Posted 30/04/04 04:23 AM Share Posted 30/04/04 04:23 AM (edited) SR71, regarding that thread you mentioned initially, I read it and all I can say is that the technical information presented is just plain wrong in relation to the Unichip – even more so on an XR6T.Regarding your other questions:1. The DTE function relies on injector duty cycle. Any mod to fuel flow or fuel pressure will cause a variance. Similarly, as the fuel pressure drops with age, DTE will change also.2. Yes, Unichip senses boost pressure and precisely maps EFI parameters for increased boost pressure.3. Unichip does not affect the Ford knock sensor circuit operation. In any case, your questions apply equally to any engine management system. Perhaps you should ask the same of others instead of targeting APS. In addition, it would be more productive for all forum members if you kept your questions specific to the XR6T.PeterAPS Edited 30/04/04 04:30 AM by aps Link to comment https://www.fordxr6turbo.com/forum/topic/10445-unichip/#findComment-116806 Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 3m 2d Gender: Male Location: Sydney Posted 30/04/04 08:00 AM Share Posted 30/04/04 08:00 AM Peter im a little confused.I attended the C&V day in Sydney recently, and asked the very question to the presenter (sorry, his name slips my mind), "Will the Ford computer register any error codes after the Unichip has been removed from the vehicle?"And the presenter said "Yes, the computer will have registered a overboost error code, but no others"I am referring to the Plug in module that was installed in the Merc Silver XR6T, rego ZADANK.Please clarify. Thanks! Link to comment https://www.fordxr6turbo.com/forum/topic/10445-unichip/#findComment-116883 Share on other sites More sharing options...
