saleen Big Gun Donating Members 4,170 Member For: 22y 8m 25d Gender: Male Location: NSW Posted 27/04/04 10:54 PM Share Posted 27/04/04 10:54 PM I'm going to go with the XR8 intake + Battens adaptor because I've been in MS700's and Trumpys chariots and they work a treat Link to comment https://www.fordxr6turbo.com/forum/topic/10407-best-air-box/page/2/#findComment-116009 Share on other sites More sharing options...
trbo 6 Member 230 Member For: 21y 4m 3d Gender: Male Posted 28/04/04 04:17 AM Share Posted 28/04/04 04:17 AM I have the APS stage 2 air box on my T along with various other mods that equate to around 260 or so at the wheels.I've got the APS Phase II and have 280rwkw, so I don't think you should have any problems at 260rwkw. Do you notice the airbox making a huge sucking noise when flooring the car?I'm assuming you have a manual as well. Good tune for 280kw. What boost are you running? I've got the auto and am running about 12psi boost, don't have a boost gauge so couldn't tell you exactly.I do hear a noise from the air box when I boot it but it's usually drowned out by screeching tyres and the turbo spooling But seriously I think the noise may be a combination of your turbo spooling up and your airbox sucking air. Link to comment https://www.fordxr6turbo.com/forum/topic/10407-best-air-box/page/2/#findComment-116095 Share on other sites More sharing options...
JB Forum Superhero Donating Members 3,109 Member For: 21y 7m 8d Location: Eastern Suburbs of Mexico Posted 28/04/04 05:47 AM Share Posted 28/04/04 05:47 AM Mines not boosted or staged, but has a second cold air intake under the front headlight with a K&N filter.(very similar to Geeas). Put the boot in and you can hear it sucking like a $2 Wh*re :lol: Then being a manual when you change gear you get a massive air flitter noise from the intercooler and probably a bit of blow off in there as well! From my experience you can never get enough air particularly the cold stuff. However if you were going to start boosting, and changing exhaust's etc it would be best to have her dynoed as you are freeing up the restrictions on the car hence changing it's performance from the original settings. As each car is different you can then taylor your fuel, air and boost ratio's to suit your personal mods, by doing that you can conpensate your settings for the amount of air you are getting and not have to worry whether the car is getting enough, and pinging! This means that she should be fine as you have the APS kit on it it will have been dynoed as such Link to comment https://www.fordxr6turbo.com/forum/topic/10407-best-air-box/page/2/#findComment-116113 Share on other sites More sharing options...
TBO240 Member 628 Member For: 21y 10m 29d Gender: Male Location: Geelong Posted 28/04/04 10:23 AM Share Posted 28/04/04 10:23 AM open your air box take the filter out and have a look at the size of the hole cut in the front of the air box you will see it is at least four times bigger then the original hole for the snorkle ....... I would stick with the aps intake. Link to comment https://www.fordxr6turbo.com/forum/topic/10407-best-air-box/page/2/#findComment-116188 Share on other sites More sharing options...
Geeseman Donating Members 1,805 Member For: 21y 8m 8d Location: Sydney Posted 28/04/04 11:12 AM Author Share Posted 28/04/04 11:12 AM thanks for all the input fellas Link to comment https://www.fordxr6turbo.com/forum/topic/10407-best-air-box/page/2/#findComment-116199 Share on other sites More sharing options...
