Guest dingah Guests Posted 25/04/04 06:06 AM Share Posted 25/04/04 06:06 AM Fearing some of the less than useful comments this might generate has anyone any knowledge, experience or suggestions for the source/cause of an audible, but not loud (only hear it with windows up, door closed and radio turned down or off below about 80kph to avoid road noise) ra[id tickeing sound directly in front of the driver behind the dash or firewall (difficult to determine) that starts at exactly 1350 RPM REGARDLESS of what is switched on or off, regardless of gear selected, roadspeed, under run or overun, loaded up or not. It is a sound like the injector rail but fiantger, lectro mechnaical not a vibration and is is persistent. From the daye of ourchase troughout the last 3000km run-in trip to QLD and return. Bloody annoying, the only cure being turning up the sound system. Listeneing intently unde rthe boonet reveals nothing, all leads, connections etc tight and checked......Any suggestions??Dingah Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 16d Gender: Male Location: Sydney Posted 25/04/04 06:22 AM Share Posted 25/04/04 06:22 AM I would check for stone or nail in the tyre (same happend to me)or it may be the fuel pump Link to comment Share on other sites More sharing options...
geea Site protagonist Lifetime Members 4,320 Member For: 21y 9m 18d Gender: Male Location: At the lights, waiting for you. Posted 25/04/04 07:08 AM Share Posted 25/04/04 07:08 AM I had a ticking sound too. It was a screw in the tyre hitting the tram tracks. Unfortunately the tyre was flat the next day. :(Geea. Link to comment Share on other sites More sharing options...
Guest dingah Guests Posted 25/04/04 08:39 AM Share Posted 25/04/04 08:39 AM It dowes it at fast idle or whenever at or beyond exactly 1350 RPM standing still or at speed, therefore nothing to do with tyres and is exactly from in front of the driver but behind the instrument panel. WHat specifically comes 'on-line at 13500 RPM?? Link to comment Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 30d Gender: Male Location: Sydney Posted 25/04/04 09:11 AM Share Posted 25/04/04 09:11 AM Does the ticking increase with revs? Or is it only there at 1350rpm? Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 16d Gender: Male Location: Sydney Posted 25/04/04 09:44 AM Share Posted 25/04/04 09:44 AM it could be a turbo problem.chipped impeller ? Link to comment Share on other sites More sharing options...
Guest dingah Guests Posted 25/04/04 10:26 AM Share Posted 25/04/04 10:26 AM Sound level does not increase with revs but speed of ticking does - the chipped impeller has been going around in my mind too, but why at 1350 RPM onwards? Once the ticking starts it's there throughout the rev range. Also Doesn't the impeller rotate considerably faster than the engine RPM and therefore would a chipped impeller be more of a whine at high speed?...... Link to comment Share on other sites More sharing options...
Guest phantom t Guests Posted 25/04/04 11:38 AM Share Posted 25/04/04 11:38 AM Dingah check all the grommets in the firewall. Noise could be injector but will travel into cab if a grommet is dislodged.Andrew. Link to comment Share on other sites More sharing options...
Guest dingah Guests Posted 25/04/04 09:59 PM Share Posted 25/04/04 09:59 PM Thanks Andy.Just checked every single grommet as suggested and ensured all resealed and the high rate clicking is still there - almost like an electrical relay fluttering whch makes it sound like a close up sound of an injector rail. The fact that no one can hear anything unusual under the bonnet and that when inside the engine is REALLY quiet with the exception of this noise makes me start to think that it is the driver's side of the firewall. It's as though it is sighted directly above one's right foot (if foot is on the accelerator pedal)behind the instrument panel(?) and I now wonder what electrical mungus dungus is oscillating to cause this to happen. As said before it kicks in a precisely 1350RPM and the rate or volume does not change throughout the rev range whether standing still or driving. Link to comment Share on other sites More sharing options...
Guest dingah Guests Posted 27/04/04 07:49 AM Share Posted 27/04/04 07:49 AM All gone thanks to a very swift diagnosis by the genius boy at Ming Automotive. Quickly tracked it down to the boost control relay pressed up against the chassis transmitting all of its oscillations throughout the car. Yippeeee! Link to comment Share on other sites More sharing options...
