Stronger Conrods for Turbo
turbotrana
  • Replies 37
  • Site protagonist
  • Member For: 21y 10m 26d
When we say stronger, what do we mean. Are they bigger or made from a stronger alloy? What are the factory rods made from?
If the engine doesn't rev any harder (because of the limiter) is there a need for stronger rods? Is it possible that with extra power the rod is forced down harder and this would be why it would need strengthening?
So many questions and so little time. :blink:
Geea. :glad:
  • Member For: 22y 7d
A stronger cast rod is usually beefier in certain areas of the rod, larger/better rod bolts, can also be of higher quality steels used and gone thru more processes to improve strength. Untill you hit 550 at the wheels stock rods are OK imo but with this engine I will go for 600+ as this is the current benchmark atm I think for a turbo6.
  • Dark Knight Mafia Member No. - 666
  • Member For: 22y 1m 12d
yeah I read in motor that the FPV F6 is getting stronger rods and valve springs, internally, and duel entry intake, bigger cooler and oil cooler externally.
  • Member For: 21y 7m 19d
  turbotrana said:
I read somewhere that FPV turbo is getting stronger rods. Does anyone know anything about this.
Also does anyone know who makes Nizpros or for that matter APS H beam aftermarket rods.
Hi
Im pretty sure that capa list some billet type rods on the web site, there are pics from memory and costing.
Cheers
  • Member For: 21y 11m 11d
The Typhoon will use the rods that are used in the BA LPG motors as they are the strongest of all the BA rods. During development of the BA LPG motors if the car backfired it would bend the rods so stronger ones had to be made. that's also why the LPG versions were delayed by about 3 months. The LPG rods are a bit heavier and thicker than the standard turbo rods so should be able to handle more power but if you were going to change them you may as well buy billet rods and some forged pistons.
  • Member For: 22y 5m 26d
I think someone mentioned on here that the beefed up rods for the F6 are actually coming from the LPG only Barra 182 engine. That's about all I can offer sorry.
Chris.
