xlnt6 Donating Members 350 Member For: 20y 3m 11d Gender: Male Location: Melbourne, Victoria Posted 26/11/04 10:27 AM Share Posted 26/11/04 10:27 AM All,Here's a few pics of the Teac DVB installed in the boot, and the antenna from inside and oustide the car. I didn't want an external ugly antenna, so I had to make do with this design which is fixed to the inside glass. It doesn't block the drivers view as it is directly behind the driver, and is not a solid object (ie you still can see things thru it). From the outside you with tinted glass you hardly can see it's there.Robin. Link to comment Share on other sites More sharing options...
HUSTLER Member 663 Member For: 21y 4m 24d Location: Broken Hill Posted 27/11/04 02:31 AM Share Posted 27/11/04 02:31 AM Just went down to my local betta electrical, and they just happend to have TWO teac dv-b400 STB on the shelf, they had 298rrp but I got one for 225 which didnt seem to bad! Still one left if anyone is interested and cant source one!Ive just hooked it up to my tele for now as I have no idea how to hook it up to the car yet Link to comment Share on other sites More sharing options...
HUSTLER Member 663 Member For: 21y 4m 24d Location: Broken Hill Posted 29/11/04 11:42 AM Share Posted 29/11/04 11:42 AM If I update the firmware now to the NTSC, can I still use it on my tele if it supports NTSC??Anyone know how the firmware upgrade works exactly? the instructions from the site wont load :( Link to comment Share on other sites More sharing options...
Scruffman Member 255 Member For: 20y 11m 28d Gender: Male Location: Prestons NSW Posted 30/11/04 06:04 AM Share Posted 30/11/04 06:04 AM HUSTLER said: If I update the firmware now to the NTSC, can I still use it on my tele if it supports NTSC??Anyone know how the firmware upgrade works exactly? the instructions from the site wont load :(<{POST_SNAPBACK}>OK first thing.You need to have a null modem cable. There is plenty of diagrams for these on the net. Dick smith dont sell these off the shelf so you ened to probably buy the parts. A bit of multicore cable. Two plugs and a bit of time to make it.There is instructions of how to do the programming of the box on the teac website but I think from memory you have the box turned off and pluged in. Start the software on the PC. Load up the image you want to download. Turn on teh box. It should start the download automatically and tell you when its done.Yes your box will work inside if you have an NTSC compatible tv. Or you could just keep changing it back between PAL and NTSC if you wish.Scruff Link to comment Share on other sites More sharing options...
Scruffman Member 255 Member For: 20y 11m 28d Gender: Male Location: Prestons NSW Posted 30/11/04 06:07 AM Share Posted 30/11/04 06:07 AM xlnt6 said: All,Here's a few pics of the Teac DVB installed in the boot, and the antenna from inside and oustide the car. I didn't want an external ugly antenna, so I had to make do with this design which is fixed to the inside glass. It doesn't block the drivers view as it is directly behind the driver, and is not a solid object (ie you still can see things thru it). From the outside you with tinted glass you hardly can see it's there.Robin.<{POST_SNAPBACK}>Robin so what is that antenna you are using and how good does it work.I am currently using two different types of vertical antenna on my car. One is through glass and the other is a standard boot mounting type. I have been mucking around with these antenna and they are tuned for UHF as well. I am going to be trying a VHF whip on it when I get around to it. I am in the process of making your little vera board curcuit at this time so I can move my unit to the boot as well.The picture I get is clear most of the time even when the car is moving only probem when mobile is the damn high pitch sound cracking as the reception drops slightly.Scruff Link to comment Share on other sites More sharing options...
xlnt6 Donating Members 350 Member For: 20y 3m 11d Gender: Male Location: Melbourne, Victoria Posted 30/11/04 09:51 AM Share Posted 30/11/04 09:51 AM Scruffman,The antenna is a Antsig Caravan antenna which has been removed from the original plastic housing (to make it smaller). Available from Kmart for about $55. It is a VHF / UHF omnidirectional antenna. I have coated the UHF parts (the four triangle pieces) with black contact and the VHF component (the loop dipole) with black heatshrink. The black part in the middle is a cut down zippy box which I have mounted the signal amplifier (which is part of the original antenna).While is works quite well outside the car, it's not as good inside, and in marginal reception areas is doesn't work well at all. I don't want a fixed external antenna, but your whip would probably work better as the signal is less masked by the bodywork of the car. When I'm moving the signal is so poor it can't be watched (that doesn't worry me, as it's a built in factor of safety !!!).I am looking at a vertical whip which should work well for VHF. A 5/8 wavelength antenna works out at 200 MHz to be about 90 cm in length. This is around the length of the electric antennas which are fitted to most vehicles, so I'm going to experiment with designing a matching / tuning circuit to match a common electric telescopic antenna for VHF reception. The intention is then to have the antenna so it only comes up when the Teac STB is turned on via the remote. Turning it off then makes the antenna retract, out of sight. Robin. Link to comment Share on other sites More sharing options...
fordboy1981 Donating Members 2,075 Member For: 21y 11m 26d Gender: Male Location: Sydney, NSW Posted 30/11/04 10:55 AM Share Posted 30/11/04 10:55 AM so has anyone made all the diagrams and part lists yet??I just want to be able to downloading it all and plug it up...I can pay you for it if you like!!Dave. Link to comment Share on other sites More sharing options...
HUSTLER Member 663 Member For: 21y 4m 24d Location: Broken Hill Posted 30/11/04 11:42 AM Share Posted 30/11/04 11:42 AM Ya, I just want a parts list and diagrams too, so I know exactly everything I need!! I downloaded one of the instructions from alot earlier, but I just got lost from the start!! Link to comment Share on other sites More sharing options...
fordboy1981 Donating Members 2,075 Member For: 21y 11m 26d Gender: Male Location: Sydney, NSW Posted 01/12/04 08:53 AM Share Posted 01/12/04 08:53 AM HUSTLER said: Ya, I just want a parts list and diagrams too, so I know exactly everything I need!! I downloaded one of the instructions from alot earlier, but I just got lost from the start!!yeah same, but I believe there are many updates since the first instructions....Dave. Link to comment Share on other sites More sharing options...
HUSTLER Member 663 Member For: 21y 4m 24d Location: Broken Hill Posted 01/12/04 11:47 AM Share Posted 01/12/04 11:47 AM that's what I gathered, theres been alot of updates and easier ways to do it!!I already know how im gunna run the sound and power it up now, I have an amp and everything already set up, its just a matter of wiring in the picture now !!! Link to comment Share on other sites More sharing options...
