  • Member For: 21y 7m 26d
  tur said:
hey great idea, one thing I want to ask u is, if hte box is placed in the boot how can u change the channels do u have to point the control towards the box or the screen?
The trick is to tap into the ICC infrared receiver (it is located on the upper part of the ICC screen surround). This will then need to be fed straight into the Dig TV box and viola! no need to point at the boot!! :lol:
This should not be to difficult. I will let you know how I go.
Cutsnake
  • Replies 301
  • Flight 6
  • Member For: 21y 10m 22d
cool let us know how it goes because I am considering doing it on my T, I rand the digital box joint up and he said they are receieving a new smaller version half the size and half the weight, it will out shortly he doesn;t know exactly when, could u post all the things needed to install the box if its not to much trouble when your finished. thankkkkk :kissmy:
  • Member For: 21y 4m 11d
The most important thing about getting a different digital decoder is it MUST output NTSC or it will not work on the T's ICC. In Australia we use the PAL system, this is not compatible witht he T's ICC.
  • I'm Back!! Thats right, long over due! :)
  • Member For: 22y 7m 21d
cutsnake, very impressive work. I'd be interested. All I have to do is convince the wife! :pinch:
  • Member For: 22y 4m 30d
cutsnake, great job.
Can you let us know have you connected up the digital box?
Did you use the scart?
Whick connections do you use?
What did you use to connect to the ICC?
Any other info to connect this up?
What type of amplified antenna are you using?
Thanks and great work!
  • Dark Knight Mafia Member No. - 666
cutsnake,
you should sell wiring diagrams, parts lists and install instructions after you have the whole thing installed nicely, I will definatley buy one.
  turb06 said:
cutsnake,
Hmmm....that wouldn't be fair on a few other forum members who have already done alot of the prework in figuring out the ICC connector pin-outs ans Aux Audio inputs (e.g. Aaron)
As I am still playing, so will post details as I go along...
just an idea, it will be good for the members that have no idea what you guys are talking about to get there hands on this once complete. I think it looks great and I want.
Thanks for the comments...
Answers to your Q's..
- Yes I am using a SCART connector for this (RGB SCART out of the Dig Box)
- I do not have access to a proper ICC connector, so I used speaker terminals pushed directly into the ICC socket.
- I am doing a basic write-up. I will post shortly.
- I am using an old Amplified Indoor TV antenna (from Tandy I think?). This has been removed from its housing as the bits I need are way smaller than the overral antenna. The antenna is the tricky part to setup for proper reception..
As I mentioned above, I am doing a basic write-up for this. This is not necessarily step by step instructions, but enough info (together with what others have posted)to get your in car TV going.
In the mean time, feel free to post other Q's / comments.
Cutsnake
