  • FORD FORD FORD
  • Member For: 22y 1m 16d
  Blown BA said:
  ktford said:
One day I'm going to have an intelligent conversation with you, I'll just have to get a lot smater first, damm brainiack makes me feel like Ken, nothing valuable to add whatsoever
Scotty CCC
Erhh excuse me that word intelligent is too good for you...stop using it.
You my vocabulary alone, my teachers did :glad: . Intelligence who needs it? :crybaby:
Scotty CCC
  • Replies 126
Posted Images
  • Site protagonist
  • Member For: 21y 11m 21d
I have been keeping an eye on my fuel economy since my Geea Stage 3 mods. Ever since I've had the car the fuel economy has been around 17Lt/100km usually 17.2ish.
Since the last mods I have used 174Lt/1140km's. This works out at 15.2Lt/100km. This isn't off the trip computer which isn't acurate any more cause of the different injector size. This is figured on Km's traveled and litres of petrol bought. This includes a trip to Seymor and back which would help.
The last refill was 60Lt/355km's which works out to 16.9Lt/100km. This is even a touch better than what I was getting. :crybaby:
When looking at these figures remember that at most sets of lights I usually floor it up to the speed limit. This wont be helping economy much.
Geea. :glad:
  • loitering with intent
  • Member For: 21y 8m 14d
Geea , like wise with my phase 2 I have been achieving approx 10 - 15% bettter economy overall. The DTE and fuel uage measures from the computer are also all over the place due to the bigger injectors, which brings me to the question , is the fuel guage affected ,as my little orange light seems to come on earlier now relative to the indicated fuel left in the tank than before my mods ? :crybaby:
  • Member For: 21y 5m 25d
  SR-71 Blackbird said:
  aps said:
Just a different view point for others to consider, it's not all about increasing power and torque, engine durability is an important consideration and high exhaust back pressure is a KILLER of turbo engine's. :outahere:
The stock exhauast system has massive exhaust back pressure at 250rwkw yet alone 300rwkw, a bi product of of high exhaust back pressure is elevated thermal loads on internal engine components (pistons, cyl head, inlet and valves).
Obviously this high exhaust B/P will have a detrimental impact on engine life ( and should be avoided like the plague) as it will on any turbocharged engine at a high power level.
Low back presure exhaust systems provide high power with lower thermal stress on engine components, which provides engine components the best chance to survive at higher than stock power levels. :bomb:
Peter
APS
? The ford engineers that we asessing the xr8 here said that the engines required back pressure. Valve life wouldn't be an issue with a turbocharge engine due to the back pressured required by the turbo. Turbo 101 has always been less restrictive exhaust better engine and turbo performance. :bomb:
Looks like I stuffed up what I ment to say was.
? The ford engineers that were here to asessing an xr8 with stalling issues said that the engines required back pressure. Valve life wouldn't be an issue with a turbocharged engine due to the back pressured created by the turbo. Turbo 101 has always been less restrictive exhaust better engine and turbo performance. :w00t2:
One of the engineers uses the prototype Typhoon as his personal drive car.
Edited by SR-71 Blackbird
  • Big Gun
  • Member For: 22y 6m 23d
Geea, very informative post As I now officially have authorisiation from the Minister For Food Import and Preparation, all I need to do is find the right upgrade package for the T. The Geea Stage 1 & 2 seems to be a very good way of upgrading the T. One question I have is after I have the Xede installed, will I need to have the car re-tuned each time I make another mod(eg. injector upgrade or exhaust?) Once again, great post and thanks for taking the time to summarise your upgrades.
Rob
  • Site protagonist
Rob
Hey Rob, thanks for your kind words. I know that if you add injectors or anything major it will need to be retuned. If you change the exhaust I would suggest a retune would be a good idea, I suppose it would depend on how much difference the exhaust made. Hopfully Lachlan will provide a more knowledgeable answer. :blink:
Geea. :ermm:
  bcl said:
Well done Geea.
You've shown you can make good power without spending big money.
By the way what fuel pump did you use!
In tank, or in-line? fyi I used a Walbro direct replacement 550HP (cost around $350).
Thanks for sharing this information.
Maybe we need a special forum where members write-up about their cars.
Brian
BCL do you have a part no? for the pump?
  • Toughest BA Turbo
  • Member For: 22y 4m 9d
Sorry, I don't, and I don't want to pull the thing out to check.... I would if it was simple.
I'd give Commsport a ring to check, or contact Nizpro.
Brian
  • FORD FORD FORD
  bcl said:
Well done Geea.
Brian
Are Walbro's locally made?
Scotty CCC
Guest LOK@ChipTorque
  • Guests
  geea said:
Rob
Hey Rob, thanks for your kind words. I know that if you add injectors or anything major it will need to be retuned. If you change the exhaust I would suggest a retune would be a good idea, I suppose it would depend on how much difference the exhaust made. Hopfully Lachlan will provide a more knowledgeable answer. :w00t2:
Geea. :pooh:
Geea, I think you actually have a very good handle on it. :thumbsup:
If it's a substantial change, it should be retuned. This should only be a small job however except in the case of an Injector change where some serious scaling needs to be done!
Lachlan
