turbotrana Member 2,586 Member For: 22y 1m 2d Gender: Male Posted 16/04/04 02:38 PM Share Posted 16/04/04 02:38 PM Thanks for sharing that info Geea. You've worked out a great power recipe at a good price. You sound like a guy where this is not the end by a long shot. You will get used to the power you have now and will want more and more and more and more. I warn you it is an adiction.Re intercooler I would get rid of the BBM and replace it with an ED inlet manifold. I would use a crossflow set up (like what Nizpro did) garret bar and plate intercooler and modify the sheet metal of the car to accomodate 2.5" pipes under the headlights on both sides for the shortest possible route. Alot are afraid to do any sheetmetal work but in my opinion to do it properly its gotta be done. Link to comment https://www.fordxr6turbo.com/forum/topic/10153-geeas-mods-part-1-2-and-3/page/4/#findComment-111873 Share on other sites More sharing options...
Blown BA In Your Face Member 6,195 Member For: 22y 1m 24d Gender: Male Location: Peninsula Posted 16/04/04 10:10 PM Share Posted 16/04/04 10:10 PM turbotrana said: Re intercooler I would get rid of the BBM and replace it with an ED inlet manifold. I would use a crossflow set up (like what Nizpro did) garret bar and plate intercooler and modify the sheet metal of the car to accomodate 2.5" pipes under the headlights on both sides for the shortest possible route. Alot are afraid to do any sheetmetal work but in my opinion to do it properly its gotta be done. Hmmm interesting thoughts you have there turbotrana, l like your thinking Link to comment https://www.fordxr6turbo.com/forum/topic/10153-geeas-mods-part-1-2-and-3/page/4/#findComment-111911 Share on other sites More sharing options...
Venom XR6 Member 1,460 Member For: 22y 6d Location: Geelong Victoria Posted 17/04/04 01:20 AM Share Posted 17/04/04 01:20 AM The ED inlet manifold wouldn't fit onto the head as the port shapes are different. A custom plenum would be easier. Link to comment https://www.fordxr6turbo.com/forum/topic/10153-geeas-mods-part-1-2-and-3/page/4/#findComment-111940 Share on other sites More sharing options...
Guest ROCKET Guests Posted 17/04/04 01:47 PM Share Posted 17/04/04 01:47 PM greetings Craigwell done with the mods, they worked a treatregardsrod Link to comment https://www.fordxr6turbo.com/forum/topic/10153-geeas-mods-part-1-2-and-3/page/4/#findComment-112103 Share on other sites More sharing options...
Geeseman Donating Members 1,805 Member For: 21y 6m 6d Location: Sydney Posted 22/04/04 02:42 AM Share Posted 22/04/04 02:42 AM Hi Geea,You looking at changing the muffler in the car? Must be restricting it at your current rwkw level. Link to comment https://www.fordxr6turbo.com/forum/topic/10153-geeas-mods-part-1-2-and-3/page/4/#findComment-114113 Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 22y 1m 15d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 22/04/04 02:48 AM Share Posted 22/04/04 02:48 AM Geeseman said: Hi Geea,You looking at changing the muffler in the car? Must be restricting it at your current rwkw level. When the T was released the statement floating around was that the standard system could allow 350 FWKW.Scotty Link to comment https://www.fordxr6turbo.com/forum/topic/10153-geeas-mods-part-1-2-and-3/page/4/#findComment-114119 Share on other sites More sharing options...
geea Site protagonist Lifetime Members 4,320 Member For: 21y 11m 21d Gender: Male Location: At the lights, waiting for you. Posted 22/04/04 03:32 AM Author Share Posted 22/04/04 03:32 AM ktford said: Geeseman said: Hi Geea,You looking at changing the muffler in the car? Must be restricting it at your current rwkw level.When the T was released the statement floating around was that the standard system could allow 350 FWKW.Scotty I have about 340-350fwkw's I believe. At the moment my exhaust is stock except for the centre muffler being removed. I think I read somewhere that the centre muffler is fairly restrictive. With it being removed, if I choose to get a little more power do you think my exhaust would be ok? Would a better option be looking at a system similar to Brian or an APS system if I feel a need for more power?Geea. Link to comment https://www.fordxr6turbo.com/forum/topic/10153-geeas-mods-part-1-2-and-3/page/4/#findComment-114153 Share on other sites More sharing options...
fordboy1981 Donating Members 2,075 Member For: 22y 3m 15d Gender: Male Location: Sydney, NSW Posted 22/04/04 03:53 AM Share Posted 22/04/04 03:53 AM so you are running the standard cat and exhuast (expect for the center muffler) with 10psi and the factory valve springs????APS seem to think this will not work...Dave. Link to comment https://www.fordxr6turbo.com/forum/topic/10153-geeas-mods-part-1-2-and-3/page/4/#findComment-114161 Share on other sites More sharing options...
Blown BA In Your Face Member 6,195 Member For: 22y 1m 24d Gender: Male Location: Peninsula Posted 22/04/04 06:20 AM Share Posted 22/04/04 06:20 AM fordboy1981 said: so you are running the standard cat and exhuast (expect for the center muffler) with 10psi and the factory valve springs????APS seem to think this will not work...Dave. With Geeas mods anything can be done :lol: Link to comment https://www.fordxr6turbo.com/forum/topic/10153-geeas-mods-part-1-2-and-3/page/4/#findComment-114220 Share on other sites More sharing options...
Geeseman Donating Members 1,805 Member For: 21y 6m 6d Location: Sydney Posted 22/04/04 06:35 AM Share Posted 22/04/04 06:35 AM Apparently the standard cat is pretty restrictive, which is why only smaller gains are made removing the center muffler, as the cat is probably the main issue.Brian has done two mods to his car mufflers, 1 involving a new 3.5 inch cat and straight through twin 2.5s to a rear muffler (I have this too). The other is a 4inch cat to twin 3's (I think) and twin mufflers at the rear. Xrsikness as this as wellIt was done at a place called Tuffy Mufflers in Sydney.Xrsikness was saying his chip went out of sync when installing the new muffler because it allowed a much more free flowing zorst, which is a good thing.As I said, I have Bcls 1st sollution, but had a centre muffler installed cause of the noise. Im now removing this again becuase I want more powa Link to comment https://www.fordxr6turbo.com/forum/topic/10153-geeas-mods-part-1-2-and-3/page/4/#findComment-114227 Share on other sites More sharing options...
