Search the Community
Showing results for tags 'xr6 turbo'.
  • Search By Tags
    • xr6 turbo ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
  1. I recently got an xtreme clutch kit put in My Falcon and the kit came with a new concentric slave cylinder, I am wondering whether the t5’s have a release bearing seperate to the CSC and if so then they re used the old one or whether the new CSC comes with an integrated release bearing? Can anyone c...
  2. Evening all. I just have a quick question regarding a BA xr6 NA+T on whether I should put 6.5litres (NA) amount or 7 litres (turbo)? Every time I go to change the oil I always forget what I should put in. (Every time……..) also on a side note, when I got home today, I accidentally st...
  3. I'm dealing with an issue on my 2003 BA turbo manual where the fuel pump relay is not getting a trigger signal from the PCM. The car is tuned with an SCT flash tuner, but this was done years ago, this issue is only recent. The fuel pump does not get a signal from the PCM to prime or run...
  4. Hey all, I have a 04 Ba Xr6T (with BTR gearbox). Looking at getting up to 300rwkw. Car is currently stock as a rock, but after researching for a while I have come up with a list of things im gonna need to support reaching that mark but without sacrificing the reliability to much. As this...
  5. G’day I have a exhaust manifold gasket that’s leaking obviously on My BA XR6 Turbo and I was wondering whether I could unbolt the 12 manifold bolts and slightly pull the manifold away and remove the gasket and then slide the new one back in and bolt the manifold back up without having to remove...
  6. Howdy, I know this has been a topic previously I would appreciate some wisdom as to whether there is a way or not to access the exhaust manifold to turbo gasket bolts and also the turbo to exhaust gasket bolts without taking the whole turbo off as I’m not well experienced in doing so, as I can’t see...
  7. Hey guys hoping someone on here can help, my car is a 2005 BAMK2 XR6 Turbo Manual. long story short I took my car to a tuner, got the car back with a very dim/faint battery light on. initially we thought the alternator was on the way out so I replaced it, made no difference. then realised the batter...
  8. So this afternoon I put My Ba Xr6 turbo 5spd into second gear and gave it a boot till around 3,500rpm and could hear a super load ticking noise coming from the engine bay, replicated the same sound, only in second and as soon as boost starts kicking in. thoughts?
  9. Does anyone know what the factory sway bar thickness is for a BA XR6 sedan? just looking at getting some new bushes while I’m at work and don’t know what size to get. Few websites reckon 24mm
  10. With all the knowledge everyone has acquired over the years, what would the best transmission fluid be to put in a 2005 BA XR6 T5 manual transmission that’s behind a 240kw Barra turbo? I know they recommend DEXRON 2 and some sort of additive but I was thinking Penrite 75w80 gear oil? (As recommen...
  11. Evening everyone, I recently had a question that despite my research can’t find a definitive answer online and was wondering if the infinite wisdom of these forums might lend an insight into it. My xr6 turbo has been tuned a few years ago and since then I have deleted the factory middle muffler (...
  12. G’day, Today I went over a stupid unsigned pipe in the middle of the road and buckled my clean deep dish 20’s that I run on My Ba XR6 Turbo, so when I got home I decided to test fit some 17x8 G6E rims that I had lying about thinking I could run them whilst my 20’s get repaired. when putting...
  13. Were can I down load a wiring diagram for a 2004 to 2007 XR6 turbo falcon can't find anything on the internet, the manuals I can get are bad for that information.
  14. Hey everyone thinking about getting a xr6 turbo but am unsure to go w a low kms ba >100000km or bf <200000km cheers
  15. G'day everyone, I have a ba xr6t and the poor bugger has over 260,000 kms I bought her at the end of last year knowing full well of the excessive kms. Unfortunately I have started to appreciate it more and more and want to keep and potentially put some more power through her. The question is....
  16. Hi there . My 2003 xr6 turbo factory falcon. Started chugging on me when I was a little low on gas . Third time now. I can't seem to run it under 30 k gas wise. So I had put gas in ( I will add I still had 33 k left. Driving just fine on motorway started chugging and shuttering so I pulled over tur...
  17. Hey lads I’m planning on building my first Barra in the near future and wanted to get a rough idea what work has to be done to the motor. I know I need to change all my rods, pistons, bearings, block and head machined ect... 1. I have read that people are running 1200+hp on a fg tur...
  18. Hey guys I’m sorta new to the Barra scene and I have bought a mk2 BA xr6 with a BF green top (gas) motor converted to straight petrol and was wondering if anyone on here has turboed one. The bloke I bought it off had blown the original motor up which was just a standard BA xr6 motor with a turbo bol...
  19. How much is a brand new unopened 50th anniversary ford picnic basket I have one and looking to sell it
  20. Hey guys, I have a 2010 50th xr6 turbo and I have an issue in regards to my cluster. I am unable to set any of variables in the centre of the cluster like my fuel consumption or digital speed reading as an example. It displays it in the small icon/tab up the yop but any time I go to set...
  21. Hi, I'm looking at exhaust options for my currently all stock xr6T BF MKII. I want it to be a little louder but am mainly after a nicer exhaust note and the ability to allow for higher flow if I choose to do some performance mods (I'm not going after any crazy kw numbers and am happy to keep it at s...
  22. Hey guys just seeing if anyone has any ideas about what I should check next. my car has a pretty bad misfire under load (basically as soon as I hit boost it misfires and carries on). I’ve got brand new spark plugs and genuine coils. Intercooler has been cleaned so there shouldn’t be any...
  23. I just wanted to learn more knowledge on my car and what I should do to reach my current goal of around 330-370rwkws, I wouldn't push any more further as I know I would be likely to do a zf rebuild so far my car has only pushed for 235kw at the wheels when iI tuned it as the previous owner returned...
  24. Hey guys, im in a bit of a pickle Ive recently blown my 6sp clutch burnt it out now she's cactus, my question is the clutch and flywheel are they a sing mass or a duel mass in the XR50 mine a 2010 XR6 ute but the xr50 model Ive been told by ford that they a duel mass and by others it's a...
  25. Hey guys. I know this is an absolute long shot. but, many a moon ago, (2010-2012, somewhere around that time) my father sold his beloved XR6 Turbo BA ute. And I'm trying to find out what happened to it. Rumour has it, it ended up in Sydney, but I'm not totally sure. It was sold in Qld. Unfortunately...
