Search the Community
Showing results for tags 'oil leak'.
  • Search By Tags
    • oil leak ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 3 results
  1. Looking for some advice on what could be causing this much oil on the front of my turbo compressor housing. Running stock piping and recently compression tested the motor with good results. Any tips on where to check appreciated. Have yet to take the turbo off the engine but will if I have to.
  2. Hi - wondering if anyone has had a similar problem and how you fixed it. BF XR6T no mods 250,000 Ks Leaking from rear main seal - seal changed still leaking. Used after market seal - replaced with genuine Ford seal - still leaking. Fitted sleeve - still leaking. Takes about one day of...
  3. Hey guys, a few weeks ago I replaced my rear left wheel bearing in my '05 xr6t BF ute. Prior to changing the wheel bearing I had no oil leaks. Since changing it, I have now noticed an oil leak in the rear left wheel arc vicinity. It is all over the brake calipers, the rotors, the wheel arch, all be...
