Search the Community
Showing results for tags 'nizpro zf'.
  • Search By Tags
  • Search By Author
  • General Vehicle Forums
    • XR6 Turbo
    • FPV PERFORMANCE INC.
    • XR8 & GT
    • G6E Turbo
    • UTEopia
    • Territory Turbo
    • Focus XR5 Turbo
    • Mondeo XR5 Turbo
    • Ford Discussion
    • Ford 4.0L N/A Discussion
    • Conversions, transplants and Frankensteins
  • General Forums
    • General Car Talk
    • Off-Topic
    • Multimedia
    • MotorSport
    • Drag and Circuit Racing
    • Photo Gallery
  • Vehicle Technical Forums
    • General Tech
    • Audio/Visual Workshop
    • Interior & Exterior Workshop
    • Exhaust Workshop
    • Electrics Workshop
    • Wheels and Tyres
    • Suspension and Handling
    • Brakes
    • Driveline Workshop
    • Turbo Workshop
    • Intercooler Workshop
    • ECU Workshop
    • Fuel System & Induction Workshop
    • Blow Off Valve Workshop
    • Engine Workshop
    • 300+ Club
    • 400+ Club
    • 500+ Club
    • 600+ Club
    • 700+ Club
  • Auto News & Reviews
    • Ford US News
  • Advertisers Forums
    • Automotive Catalogues and Specials
    • Advertiser Q&A / Feedback Forum
  • Cruise & Event Forums
    • Scheduled Events Forum
    • General Discussion
    • Australian Capital Territory
    • New South Wales
    • Northern Territory
    • Queensland
    • South Australia
    • Tasmania
    • Victoria
    • Western Australia
    • New Zealand
  • The Market Forums
    • Classifieds
    • Small Business Directory
    • Group Buys
  • The Site
    • Site Announcements
    • Merchandise Forum
    • Suggestions, Problems or Questions
Product Groups
  • Advertisements
  • DM Packages
  • Merchandise
    • Stickers
    • Key Rings
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Found 1 result
  1. hello all , after a long road ive just got the first tune on my xr complete so far its made 395.5rwkw on 98 with a easy tune running 18psi next step is to switch up to barrel e85 change the fuel reg and fuel rail and go for 430-450rwkw and go for a mid 10 pass so far the car had ran a 11.8 @ 116mph (322kw) with the baby turbo with out cams or oil pump or fuel system I raced it and ran the 11.8 only to drive back to Townsville and the stock turbo let go as we got home (thank god mackay is 4hrs away) so I race out and brought a gtx3582r and bolted it on took my rear housing to mtq and got it ported and bolted it all back together, drove it over to tms (about 1klm down the road) for a quick touch up tune to make it driveable before upgrading the fuel system to suit the bigger turbo mtq stuffed up the mod and didn't install a large enough flapper and the tuner was unable to control the boost below 18psi and that's way to much air for the stock fuel system to cope with so I drove it about like a diesel only reving it to 3500rpm for like a month till I had the money to start the next round of mods about a week before it was booked into start the mods my missus rang me up and said its making a bad noise when it revs about 2000rpm, I told her to drop it over to tms straight up and see what they think turns out the cam chain guides and tensioner are fok'd. than im told that to get to the bolts for the guides you need to drop the sump :/ so I ended up getting it fixed and while its all apart I got the tbre oil pump with billet gears and a set of tbre stage 1 cams, along with a plasmaman surge tank with twin 044s (only running one atm with 98 tune) and a retune after a bit of trial and error the tune is good making good power with a lumpy idle ( cams ended up being much more aggressive than first thort) its been a rough ride getting it to this stage but its all done properly with just about every surport mod I could do to keep it safe at this level basically the only thing left to do is to build the motor and go a new turbo set up with boost 6 manifold mods so far include rapid systems intercooler and piping turbo side intake with relocated battery to oppersite side 4inch exhaust turbo back 1000cc id injectors 38mm turbosmart bov gtx3582R turbo with mod'ed gate tbre oil pump tbre stage 1 cams (apparently equivalent to atomic stage 4) plasmaman surge with twin 044 all wired up for both only running 1 atm new oil line with filter for the turbo xcal 3 adjustable suspension molly tale shaft built about 5 times by hardy spicer cause there spaz and couldnt get it right for some reason nizpro build zf stage 2.5 with billet intermediate shaft good for about 600kw ( cost lots!) mt 275 street radials hoping for 10.9 with 98 and mid 10 with e85 wish list for the future tbre built motor good for 1000hp + boost 6 turbo manifold twin external gates gtx45 turbo at least a 9.9 sec pass but im waiting for e85 to be at the pump before I get a built motor this not sure if I have to do the fuel rail to run e85 if I should go a gtx 45 turbo or a gtx 42 what 1000cc id injectors max out at and whats the next size injector I should run to go 600-700kw if I should get the crank done when I build the motor what the go is with the destroker kits and if its worth it any help would be great
