Search the Community
Showing results for tags 'limp mode'.
  • Search By Tags
    • limp mode ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 12 results
  1. Hi everyone, I currently own a G6eTurbo 2010 model with approximately 100,000 kms. I have done nothing to the car besides a rear muffler delete, besides this it is stock as a rock. The other week I was driving on an expressway travelling at about 100 kmh and then accelerated, not...
  2. 02 ba turbo ute in limp mode Parked up ute put in new injectors and fuel pump. Went to tuner ute was in limp mode was fine before installing the items. In process if changing fuel pump broke a abs wire and soldered back together. Auto elec said abs is all reading right. car w...
  3. Hey So I have a 03 BA XR6 Turbo and it seems to be having an issue that the mechanics can't seem to find so im coming here in hopes for answeres! After driving my car for about an hour or 2 it will go into I guess limp mode where I can rev it but it won't physically go anywhere you ha...
  4. BF XR6-TURBO not starting. faults codes PRNDL Sender Failur U1900 CAN COMMUNICATION FAULT P1000 OBDII Not completed cycle. not starting in any gear. couldnt locate inhibitor/ park neutral switch on ZF transmission. any ideas??
  5. SamBarra
    Limp mode
    My Ba Xr6 Turbo keeps going into limp mode after a 10 15 minute drive , doesn’t go into limp mode from cold start , but after a 10-15 minute drive then come to a stop or if I put it into Neutral or park it will go into limp mode after a few minutes times vary any help will be much appreciated
  6. Hi there needing some knowledge and advice, I've got a 2003 ford ba xr6 turbo auto. I've owned it for around 2 and a half years now and it's always had problems, biggest one is when you put your foot down and hold boost for more than 3 or for seconds it starts to shudder really bad and go into like...
  7. Hi there needing some knowledge and advice, I've got a 2003 ford ba xr6 turbo auto. I've owned it for around 2 and a half years now and it's always had problems, biggest one is when you put your foot down and hold boost for more than 3 or for seconds it starts to shudder really bad and go into like...
  8. Was driving my 2011 G6ET with trailer out of town couple of days ago and then randomly after 2+ hours driving (at night) the tail lights went out so pulled over turned it off and found the blown fuse and replaced to found the lights where back on so all seems fine so I went to start the car again to...
  9. Was driving my 2011 G6ET with trailer out of town couple of days ago and then randomly after 2+ hours driving (at night) the tail lights went out so pulled over turned it off and found the blown fuse and replaced to found the lights where back on so all seems fine so I went to start the car again to...
  10. Hi all, I have recently replaced the turbo, new front mount, new piping. Basically had most of the induction and exhaust apart. I have put the car back together and its running but it goes into limp mode. Car wont throttle over 2-3000RPM, I figured I forgot to plug in a sensor. Went over all of the...
  11. Hello all, After a lot of researching and testing for the problems of my car going into limp mode it has been found that the ECU is cooked.. I have a 2003 BA XR6T 4 SPD AUTO and I am trying to replace the ECU. It apparently is the early ECU's which is a ABU214.. Can anyone help me/give me advice whe...
  12. my ba xr6t is now in limp mode, no speedo, in sequential shift mode, will only go into 1st n 2nd than hit roughly 3000rpm and it shudders than feels like its stuck in third. things ive tried so far - had a mechanic scan it and showed speed sensor error, would not let us clear error and nothing shows...
