Search the Community
Showing results for tags 'fuel vapour canister purge outlet'.
  • Search By Tags
  • Search By Author
  • General Vehicle Forums
    • XR6 Turbo
    • FPV PERFORMANCE INC.
    • XR8 & GT
    • G6E Turbo
    • UTEopia
    • Territory Turbo
    • Focus XR5 Turbo
    • Mondeo XR5 Turbo
    • Ford Discussion
    • Ford 4.0L N/A Discussion
    • Conversions, transplants and Frankensteins
  • General Forums
    • General Car Talk
    • Off-Topic
    • Multimedia
    • MotorSport
    • Drag and Circuit Racing
    • Photo Gallery
  • Vehicle Technical Forums
    • General Tech
    • Audio/Visual Workshop
    • Interior & Exterior Workshop
    • Exhaust Workshop
    • Electrics Workshop
    • Wheels and Tyres
    • Suspension and Handling
    • Brakes
    • Driveline Workshop
    • Turbo Workshop
    • Intercooler Workshop
    • ECU Workshop
    • Fuel System & Induction Workshop
    • Blow Off Valve Workshop
    • Engine Workshop
    • 300+ Club
    • 400+ Club
    • 500+ Club
    • 600+ Club
    • 700+ Club
  • Auto News & Reviews
    • Ford US News
  • Advertisers Forums
    • Automotive Catalogues and Specials
    • Advertiser Q&A / Feedback Forum
  • Cruise & Event Forums
    • Scheduled Events Forum
    • General Discussion
    • Australian Capital Territory
    • New South Wales
    • Northern Territory
    • Queensland
    • South Australia
    • Tasmania
    • Victoria
    • Western Australia
    • New Zealand
  • The Market Forums
    • Classifieds
    • Small Business Directory
    • Group Buys
  • The Site
    • Site Announcements
    • Merchandise Forum
    • Suggestions, Problems or Questions
Product Groups
  • Advertisements
  • DM Packages
  • Merchandise
    • Stickers
    • Key Rings
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Found 1 result
  1. So recently working on the old mans GT I was installing some injectors getting ready to " I <3 Bananas send it" lol. Everything went sweet apart from this bloody vacuum connection that broke behind the intercooler. From research it seems to be quiet common but no detailed fixing instruction so here you go. This fitting is connected to the fuel vapour canister purge outlet. As you can see here this is how mine broke with the thread still stuck. Being in such a *beep* of a spot I decided rather than trying to get hands behind there it was easier to just take the intercooler out. To do this start by disconnecting your oil breather from your air intake piping then take your air intake piping out by loosen the hose clamps each end and wiggling the hose off each end. Next take the 10mm bolt out holding your engine oil dipstick to the throttle body housing as you'll need to shift this a little to get the throttle body out. Next disconnect both connection to the throttle body then take out the 4 bolts holding the throttle body and remember to grab the gasket and not let it fall down into the engine bay and look after it!! Might even be worth inspecting and replacing. If you're experiencing the main issue here you know how temperamental these cars get with a simple air leak lol. Shimmy the dip stick out of the way to slide the throttle body out. Next you need to disconnect this "hat" or bracket. They are a 5mm hex bolts so be careful not to round them like I did 🤦‍♂️ Next start taking out the torx screws holding the 335 plate down. From memory I think they are a T20 bit. Once that's off disconnect the T-map sensor plug and move the wiring out of the way, The sensor can stay in. The rubber under the 335 plate is a charger "silencer" from what I was told... Ours looked good in the bin 🤷‍♂️ Next start taking out the 8mm bolts holding the intercooler housing down. You will need a 1/4" uni joint socket and a small extension to get the back 4 bolts out, Handy to keep a magnet on hand as well so you don't drop any bolts down into the bay. Now the housing should just lift straight out. Next take the 6 bolts out holding the intercooler down then just lift the cooler out. Now there's plenty of room to get the thread out, I just used a thread extractor tool. With the tube still connected to the fitting you just push in and hold down the fitting end then pull the tube out. Now I went to Enzed to get some metal fittings because F*#! ever having to do this again because of cheap plastic. The parts I got (on my Enzed receipt) Product code - A72-0604 72 3/8X1/4 M&F Adaptor Product code - 20003-M0806 M STR 8mm Tube X 3/8 BSPT You will also need to disconnect the oil breather line just to screw this fitting in. Now just push the hose back into the fitting and reverse all the steps to put it all back together Hope this helps anyone who has this happen to them and hey.. Least you know how to do half of the job installing a after market intercooler 😈
