Search the Community
Showing results for tags 'ford falcon'.
Evening all. I just have a quick question regarding a BA xr6 NA+T on whether I should put 6.5litres (NA) amount or 7 litres (turbo)? Every time I go to change the oil I always forget what I should put in. (Every time……..) also on a side note, when I got home today, I accidentally stalled the car 🤦♂️ because the clutch is on its way out and with the key still in the ‘on’ position but the engine off after stalling, there was a chiming sound and the oil light flashed after about 3 seconds. Anything to be concerned about? definitely has good, clean oil in it.
Howdy, I know this has been a topic previously I would appreciate some wisdom as to whether there is a way or not to access the exhaust manifold to turbo gasket bolts and also the turbo to exhaust gasket bolts without taking the whole turbo off as I’m not well experienced in doing so, as I can’t seem to reach them when having the car on a hoist or from above, I would prefer to do it myself rather than take it to a mechanic because of the labour cost. The vehicle has a shocking exhaust leak at the moment and it’s coming from one of the turbo gaskets, definitely doesn’t seem to be the exhaust manifold gasket. It’s a loud ticking under load and whistling+ticking under boost, when rev matching it almost sounds like a car without an exhaust manifold lol. Just want it fixed asap. thanks
How much is a brand new unopened 50th anniversary ford picnic basket I have one and looking to sell it
- 12 replies
- ford falcon
- ford xr6 turbo
(and 5 more)
Tagged with:
Hi there, I have a 2006 BF XR6 Falcon. All of a sudden my cluster and park lights stopped working.. My indicators, low/high beam and break lights work fine, pulled all fuses and checked them and all was good? Also I seen some other forums about this issue and seen that the combination switch are a common issue, so I checked that and didnt see any stripped/cut wires on the sharp turn of the green clip that pushes into the socket above the ignition and down the rest of the wires? Quite stumped tbh...Does anyone know what or if theres a fuse for the parking lights? Found the cluster fuse too but that was fine. Cheers & thanks Levi
I have a BF XR6 and the motor is in very bad shape. I have a greenhead gas Barra that I pulled out of a BF, if I ran that on petrol, would it be slower?? Or faster??? I know the gas Barra has higher compression but with the more heavy duty rods will my power output be less? And no I can’t turbo it because I’m on my Ps lol.
- 2 replies
- gas
- barra swap
(and 7 more)
Tagged with:
Hello, I am new to this forum and new too cars as I am wanting to learn, please no harass or trolls but, I have a ford falcon v6 and is it possible to take it out and put a xr6 turbo in it? Or is that not possible? Thankyou
- 33 replies
- 1
- Ford Falcon
- V6
(and 2 more)
Tagged with:
