Search the Community
Showing results for tags 'btr 4 speed'.
Hi Gang, Long time lurker, first time poster. Been re-searching higher stall converters for the BTR in my BA mk2 in the hunt for better 1/4 mile times. I've had a poke around but can't seem to find a direct answer. If I install say, a 2800 converter, will the car go into limp...
- 3 replies
- btr 4 speed
- btr
(and 2 more)
Tagged with:
Hi guys new here on this forum so I’ve just purchased a ba XR6T ute stock as a rock. It has a noisy output shaft, (sounds like a wheel baring failure) but it’s 100% the output shaft as it’s got in/out and side2side movement. Otherwise box works as it should no slipping or jolting. The Utes transmiss...
Hey lads just seeing if anyone has purchased off or used rvo automatics to build their tranmissions and what was the quality/workmanship like? Im looking at a rebuilt BTR4spd from there for my ba xr6t , its rated at 400kw but before I spend any money id like to get a little more info and hear the op...
Has anyone fitted a PWR trans cooler kit PWO6115 to a BA XR6T - will the mounting brackets in the kit mount up fine behind the factory intercooler?
- 1 reply
- btr 4 speed
- ba
(and 1 more)
Tagged with:
Want to know rough power figures I can expect from get my ba xr6 turbo it has a sports 2half inch cat back. Is getting 1000cc Bosch injector walbro 460 in tank pump bigger cooler 3inch piping same as plazmaman stage 2 with a under headlight intake.and fitting crow valve springs and retainers only th...
