Search the Community
Showing results for tags 'boost leak'.
  • Search By Tags
    • boost leak ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 4 results
  1. It's a very long story so I'm going to try and keep it as short as I possibly can. Last week I had an Antz Performance turbo side induction and battery relocation kit installed in my 2011 FG XR6 Turbo ute, before this kit was installed I had absolutely no problems with my turbo, no probl...
  2. Turbs6
    Boost leak?
    Hey guy, I have a 07 bf xr6t auto stock apart from hotside piping, cooler and tune from previous owner. I recently replaced the rubber joiner on throttle body with silicone hose that stopped boost leak and revs issue. I now however have what seems like an intermittent boost leak from tu...
  3. Hey all, Having a boost issue with my BA (Cooler, 4 inch dump & exhaust, injectors, X4 with custom tune 297kw@14psi, currently running custom 10psi safe tune), 1st will boost to about 5psi the 0psi, 2nd will spool up then 0psi, currently nursing. No fault codes appearing, so far have checked/r...
  4. Hey everyone, I just picked up an xr6t ute last night and was giving it a fair bit since I haven't owned a 300kw+ car before, at some point of the night I found out how to take traction control off and got on the brakes, once I clicked 2nd for a while I heard a pop but thought it was from the exhaus...
