Search the Community
Showing results for tags 'ba xr6'.
Evening all. I just have a quick question regarding a BA xr6 NA+T on whether I should put 6.5litres (NA) amount or 7 litres (turbo)? Every time I go to change the oil I always forget what I should put in. (Every time……..) also on a side note, when I got home today, I accidentally st...
G’day I have a exhaust manifold gasket that’s leaking obviously on My BA XR6 Turbo and I was wondering whether I could unbolt the 12 manifold bolts and slightly pull the manifold away and remove the gasket and then slide the new one back in and bolt the manifold back up without having to remove...
Howdy, I know this has been a topic previously I would appreciate some wisdom as to whether there is a way or not to access the exhaust manifold to turbo gasket bolts and also the turbo to exhaust gasket bolts without taking the whole turbo off as I’m not well experienced in doing so, as I can’t see...
Does anyone know what the factory sway bar thickness is for a BA XR6 sedan? just looking at getting some new bushes while I’m at work and don’t know what size to get. Few websites reckon 24mm
With all the knowledge everyone has acquired over the years, what would the best transmission fluid be to put in a 2005 BA XR6 T5 manual transmission that’s behind a 240kw Barra turbo? I know they recommend DEXRON 2 and some sort of additive but I was thinking Penrite 75w80 gear oil? (As recommen...
- 8 replies
- t5
- transmission
(and 5 more)
Tagged with:
Thinking about replacing my NA Ba xr6 front bumper with an fg style one, already has a boss hood and a bobtail. My mates think its ricey to swap parts between the different models but I think it's tasteful. Honest opinions please
I've just purchased a completely stock 04 ba xr6 n/a I have a worked bf f6 motor apparently to about 450 rwhp with all the loom ECu etc, just looking for advice reccomendations and possible problems I might encounter with my conversion
- 3 replies
- fpv
- conversion
(and 1 more)
Tagged with:
Hey guys, I have a 2003 BA XR6, with Pacemaker 4495 Extractors 2.5" back exhaust., and a F6 Lower Snorkel for the intake with K&N Panel Filter. (didnt see the money in the growler) They are the only mods ive done to the car, and I put it on the dyno today to just get a power figure. I was just using...
Turn On Wipers/brake System Malfunction Light Appears
xr6wipers posted a topic in Electrics Workshop
TODAY WHILE DRIVING IN THE RAIN I PUT THE WIPERS ON ONLY TO SEE THAT THE BRAKE SYSTEM MALFUNCTION WARNING LIGHT CAME ON. ONCE I TURNED THE WIPERS OFF THE LIGHT WENT OFF. NOT SURE IF IT IS EARTHING, WIRING ETC... NEED TO FIND OUT WHAT PROBLEM IS.
