Hi I have a quick question I cant find the answer for, does the BF XR6 Turbo 2 bar map sensor use the same plug as the NA BF XR6 map sensor. I have just fitted a turbo to my NA BF XR6 and is currently running with a rising rate fuel reg and everything else still stock, but it will be going in for a full dyno tune shortly & just before that I plan to fit new injectors and a 2bar map sensor, now I have read and know about changeing the wires around but cannot find any info on if the plugs are the same and as it wont go once this is done untill flashed I wont to make sure I dont get caught out with the plug not fitting. P.S here is a couple of pics of my turbo fittment
