redhot
  1. Hi, I was just wondering if anyone try to put there leaf springs on the bottom of the axle? This is the first Ute I got and first time working with leaf springs just wondering if anyone has try doing it and any advantages or disadvantages in moving on the bottom! thanks
  2. Hi everyone, I got the Ute started today! you’ll all laugh how I did it! I just charged the battery that’s how simple it was! I like to say thanks to everyone that commented on my post! COMM FAULT = CHARGE YOUR BATTERY!
  3. Hi guys, no good the car is still sitting in the drive way doing nothing, I changed the battery and used forscan to scan the codes but still no start….doing my head now, I have changed the cluster hoping it was a cluster fault but after the cluster change it still says coms fault. Not to sure if I should get it towed to ford dealer or something. Anyone have any ideas?
  4. I need some help as my ford fg turbo Ute won’t start for some reason. It just happened one afternoon when I jumped in to start it and the car started but stalled and after that I haven’t been able to start it again and I have noticed that the indicator ain’t working when I press the key fob and that the cluster is on even after I have locked the car it’s still on and it’s pulsing going dim every minute or so and when I put the key in the barrel and turn it to start nothing shows up on the dash but everything else turns on like radio and aftermarket gauges all runs normal but nothing on the cluster at all. I have replaced the battery so that’s new! checked all the fuses didn’t see any blown, check the connection from the starter motor, not sure what else it can be and it’s doing my head in. Honestly any advised would be appreciated! Thank you!
