04RSD
  1. hey guys im fitting an barra engine in my ED and was wondering if you can run a cable T/B on the barra engine? deleting the drive by wire pedal is so there is one less thing to modify and possibly go wrong. thanks
  2. YAY I got it running. had a mate with a decent scan tool come out and re program the keys to the bem. heard nothing from ford coming out to do it after they said they would.
  3. I found out that leaving the ignition on for an hour with 13v or above ( put car on battery charger ) will reset pcm and it will do a self reset so guess what im doing after I get home today??
  4. Well surprise surprise the ford tech didn't show and when I rang the service manager he said I was booked in to drop the car in there. So why did I have to give them the address where the car was? How can I Hotwire this thing to test run it???
  5. I reset all the codes (which there was alot of) but it still wouldn't start so I rescanned and the BEM said wrong transponder key tried to start the car. Spoke to ford and they said yeah if it sits too long without power the car forgets the keys and remotes. It needs to be reflashed. $110 and they are coming out to do it tomorrow. Fingers crossed it works. I'm putting the motor and box plus factory turbo in my ED
  6. the icc hasnt been changed out, the guy said he turned the car off after it hit the pole it got towed away and he never tried starting it since then. im trying to make sure it all works before I pull it out and fit it into my ED
  7. hey guys I hust got myself a written off 5 speed ba xr6 for a donor vehicle. its been sitting with a flat battery for a good 8 months, I put a new battery in but no luck. my radio is showing CODE with ign on ( as soon as you turn ign on it should talk to bcm and power up ) there is no crank, a few of the dash lights drop out as normal on crank but the little hand with the key and the red (!) flash up, im guessing dead bcm but im just guessing. I have a snap-on ETHOS scan tool but its pretty much useless for anything bigger than resetting seatbelt and airbag codes. any help would be great. I want to have a quick drive to make sure sure everything works ok
  8. I saw a 20" dark argent wheel and I JIZZED IN MY PANTS
  9. another of daves cars on the night ran a pb of 11.4 BUT dave knows how to make the 6 speed autos leave the line on full boost so when your a bit too keen on the hand brake foot brake and throttle, something has to give. notice mick in the background repeating his advivce to stop being so concervative on the launch, he he he grizzly by name grizzly by nature http://au.youtube.com/watch?v=Q-BlFJe7mrA
  10. kent and dave worlds fastest purple twins 10.77 and 10.71 on the same friggen run http://au.youtube.com/watch?v=EFw4cD0GIto oh that noise would put a horn on a jellyfish
  11. jCeJ3nyCchs thank you thank you
  12. 04RSD
    Im In 352rwkw
    I LIE deca 60s, full plazmaman kit, pump and blueboosted. stock exhaust
  13. which shop did that and what town I have been fitting for 10 years, self taught and I have never ever wanted to play in fibreglass but its soooo sexy you would be amazed what I can do with a flat piece of mdf but nothing like that. it makes me think I should give up and go make burgers at maccas
  14. well its back in my garage BROKEN ill wait till they have my diff in stock then tow it back in. my tranny cooler and nizpro flex plate went in while it was off the road too ( with help from a couple of flat bed trucks ) com' on end of month
  15. hey dags when I fisrt fashed my ute with the standard pump I got fuel surge by the top of second gear with anything under 150ks till empty. that's why I fitted external and swirl pot. I hope you dont have the same issues
