Dextaminggg
  1. 02 ba turbo ute in limp mode Parked up ute put in new injectors and fuel pump. Went to tuner ute was in limp mode was fine before installing the items. In process if changing fuel pump broke a abs wire and soldered back together. Auto elec said abs is all reading right. car will go up to 110kph stays in 3rd no speedo all prnd flashing. has Canbus fault on scanner and sometimes speed sensor have Replaced abs pump,tried a engine ecu (only plugged in not programmed to start) replaced fusebox. Check wiring. Reset code on gearbox. Cleaned gearbox wiring. please help this has been a pain for months and no one can find the issue
