gleno
  1. Key seems to b working fine relay clicks in fuse panel next to key,switches 12 volt to starter relay and fuel pump relay underbonnet car starts and drives fine when it's cold outside got home from work today 28 degrees didn't want to start poured some cold water over ecu and it started ran for few minutes and stopped then tried water again but didn't start,thinking it's ecu problem
  2. Thanks
  3. No stock standard besides pod filter 150k KMs I got home today from work it wouldn't start poured cold water over ecu started straight away ran for few minutes then wouldn't start again
  4. Just purchased ba xr6turbo manual problem starting when ambient temp is above 25 degrees,drove it to work at 6 in morning ran fine went to start it at lunch wouldn't start had dash lights no fuel pump or start ,I'm an autoelectrician if I bridge 30 and 87 on fuel pump relay and jump 30 to 87 on starter relay underbonnet with key on it starts and runs,it's getting 12 volt to fuel pump pull in contacts 85 and 86 and it gets starter signal from key on starter relay but they won't energise checked relays there fine ,
