Hi guys,
I recently bought a fg xr6 turbo a few days ago. It has 77,000kms on it. Only mod it has is a Herrod intake. The car had been sitting for 6 months. Battery wasn’t the best.
Day one I took it for my first test drive, power was great and could really hear the stock blow off valve when boosting (at the time I didnt know if they are meant to be that loud or the after market intake made it louder).
day two I backed it in and out of driveway was a bit hard to accelerate, felt like spark plugs were slightly fowled but went away after a few minutes but notice this when car is cold now.
Day 3 I removed the battery to give it a charge and noticed a clamp on the intercooler pipe was loose and pipe had come out slightly so I put it back in and tightened the clamp. I decided I wanted to wash it but windows were down and battery was out so I connected a battery pack to wind window up but it didn’t work so I connected a big battery and eventually got the windows up. I charged the original battery for only 3-4 hours whacked it back in and took for a spin and could barely feel the punch of the turbo and blow off valve noise slightly only in first gear. The car drives really smooth when warm just feels under powered. No engine light or fault codes. I tried removing boost solenoid and just connecting wastegate straight to turbo but made no difference. I replaced the battery, still nothing. I connected my scanner to check boost pressure and it says it’s running 14 psi on full throttle. I disconnected a intercooler pipe to feel power difference as I couldn’t believe it was boosting that much then drove it and it was very slightly under powered but not as much as it should be when disconnecting the turbo. I could hear turbo spooling loud and clear after disconnecting pipe.
In all honesty the car feels like it’s running 2-3 psi but very smooth to drive with no fault codes. My next move will be changing the spark plugs and fuel filter but I can’t see these making a dramatic difference.
Sorry for the long post, just trying to give as much detail as possible to see if anyone would have any suggestions?
Thanks in advance.
