Fulloutsick
  1. Hey all I have a bf xr6 turbo and having a really strange issue. The car runs perfect and has the usual bolt ons on it makes 300rwkw. When the car is warm though, once I turn off the engine then try to restart it, it starts easily but then dies instantly. Its gotten abit better now so it starts then revs rise and fall abit then is as normal. Any ideas?
  2. Just bought the car so im not sure if tuned. The trans was reconditioned as the old on milkshaked and the diff oil before I drained it looked like it was changed already. The ecu thought has been out before as the screws are normal hex head ones.
  3. Hey all, I have a fg xr6t and have a really strange issue. So im aware of zf lurch but for some reason mine is much more noticeable than other falcons ive driven. Also if I put the car in manual mode in first gear, and go on and off the throttle constantly (about 20% throttle just lightly) I feel a clunk and a sort of backlash too. Diff bushes are good, center bearing good, tranny and engine mounts good. Everything seems fine. Any ideas?
  4. Its really annoying coz you can hear the him module moving as you select through the different modes. Im guessing its the box in the center of the dash and the vents are stuck sometimes and doesnt change. Does anyone have a picture or know exactly how it works?
  5. Is there even a shaft that adjusts air direction? I know that the temperature controls have the rods that are known to snap but the air direction works sometimes not all the time so im not sure.
  6. Hi all, my bf falcon has started to have an issue where I cannot change the air direction from like face to feet or to the demister. It just stays on the face vents constantly. Both the heater and air conditioning work aswell as the dual zone feature. Has anyone encountered this issue before. Thanks for the help in advance :)
