Hellz K9
  1. Thanks gents I will look into this. RPM isn't to much of an issue car is limited anyway but I will put a oil pressure gauge and sender in.
  2. Turns out that OBD2 reader and gauge sets are very cheap, so I'll try that.
  3. Thanks for the help guys. I had hoped that to that I could remove the AC compressor without spending the the $250 on the delete pully. I didn't know that some Barra's came out without ac. Ill check the wreckers round town. Cheers
  4. Hello, Does anybody know if there is a serpentine belt for a BA Flacon that can be used with out the ac pulley?
  5. I've striped the interior of this car so no ICC, BEM or cluster. I've got the the security stripped of the ECU so the car runs fine. I want oil pressure, engine temp and tach gauges but I don't know enough about it all. I have heard the easiest thing to do for the tach is join into the injector pulse, ideas? Can I use the existing head temp sensor with a different gauge? Is the best thing to do for the oil is to tee off the oil pressure gauge and add a new sender? Cheers
