Packmeapipe
  1. my creader throws the same code but my t/c light doesnt turn on till I drive for about 20ish minutes, the creader also tells me my steering angtle at straight is ten degrees out (cars had a wheel alignment to this and drives dead straight with wheel slight tilt the people I bought it off had the alignment done) how do I run a calibration test im not sure if my creader does those? or is it simple enough to disconnect and rotate it myself and keep checking with the creader till its right?
  2. I know about the vavle springs being rubbish cheers for the knowledge on the actual valves. its my understanding that the pistons are also different turbo has recesses for lowering compresion?
  3. would it not be possible to if you were going to take and na motor and boost it and use 100% stock turbo parts also pilfer the turbo'd cars ecu would its normal map not be ready for basic boost?
  4. who built it and how much roughly
