phil34
  1. cheers, thanks for the link.
  2. thanks, I'll go and check that out. I also found after searching that raceworks sells the correct plastic fuel tubing to use on the pump
  3. yep. that's the one. it does fit in if I squash it in and it makes it very tight to re-assemble. I was just hoping that being such a common conversion someone may have found a strainer that was better suited.
  4. I 've recently tried fitting a walbro 450 fuel pump, and found that the strainer provided is too big for the falcon fuel pump module. is there a strainer available that others have found to be a better fit. don't really want to install it without one.
