bitcrusher
    Melbourne
  • Interests
    Sluts
  1. yeah got carried away I realise it was dumb as I <3 Bananas but did it any way
  2. So I have a few mods and recently installed a 15 psi turbo smart wastegate and while there I ported the waste gate hole as it had flapper mod but the hole wasnt opened up car has 1000cc injectors 3.5 inch exhaust 4 inch dump 460 walbro pump, valve springs oil pump gears. its has a base map mail order sct tune to get it moving so I can take it to dyno took it for a squirt gave it alot, it boosted to 22 psi quite hard than I realised backed of and cruised home car had a rough idle on way back sounded like it wasnt running on all cyclinders will take it for a run around block tonight see if its still same
  3. How am I gonna go about checking that? I can check out of the pan buy id have to cut oil filter no?
  4. As stated thought id clean the oil filter line to turbo found a few small specs I purchssed this car earlier this year as un finished car wasnt all that well looked after the last 12 months before I got it has shown. Any wa back to the point im gonna checj in a month if there still there (dont drive this car often as its now my project) whats the go once I find these how do I fins where and its pretty much a time bomb now or? Thanks
  5. Legend explains it there are colors on springs. So a combination of them allows me to go higher and lower im assuming or only 1 at a time? Scrap that read the picture some more all makes sense now thanks all!!
  6. Should have put more information in that. I mean can this setup of springs come fron turbosmart?
  7. So this setup can come from factory?
  8. car is running 15 psi with a boost t and stock actuator has supporting mods. the one I have has 3 springs in it its that springy its hard to put the cap on
  9. Just purchased second hand turbo smart actuator apparently been on car for 5000ks before going external gate. how many springs are meant to be inside? Bloke told me its 14 psi and than said car was making 23 psi
  10. hello! Any one here playing games on pc and what is it? Interested in finding some people to play with currently am playing cod mw can find me at https://discord.gg/U9fh7Z2
  11. so it arrived and I installed it..... does work though I still have a dose running 15 psi
  12. I did try one cleaning method but ill have to try that one thanks
  13. Conpletely agree but when you dont make lerge amounts of money its little harder. Trying to get it road worthy for now and will be purchasing a new belt the brand is SRP any good?
  14. Its pretty straight forward so I dunno
